Ao Smith Promaxx Wate Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2009, 09:21 PM   #1
ao smith promaxx wate heater
The heater will not stay lit. It seems to be an air flow problem and I need to clean the burner assembly. To do this, I need to remove the burner. Do I just detach the three lines at the bottom of the valve and pullout the whole thing out or will this cause more problems. Anyone who has done this, I would appreciate any tips. This heater is not 5 years old and I can see on the net where this is a common problem with the ao smith's. If I call a plumber, I'm getting a new and different heater the first trip. Thanks
JohnK120 is offline   Reply With Quote
Old 03-19-2009, 12:42 AM   #2
HVAC / Plumbing
If this is the type with peizo ignitor button the side for lighting the pilot. You will need a new gasket seal kit so that the burner area is sealed back once you remove the burner assy. Could be air flow ,thermocouple , bad valve/ thermostat
kenmac is offline   Reply With Quote
A O SMITH gas water heater problem joeyuk Plumbing 62 01-24-2013 12:31 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
