AO SMITH ProMax Relighting Problem !!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2011, 07:29 AM   #1
I have a 5 yr old 50 galllon ao smith gas water heater, no hot water starting yesterday night....... tried to light pilor a dozen times, but no luck. cannot seem to get it lit again... i have followed book & instruction on water heater to relight, but no luck... this is how i tried to relight.....IN THE OFF POSITION, I TURNED KNOB TO PILOT, PUSHED DOWN, PRESS THE IGNITOR BUTTON NUMEROUS TIMES, BUT NO LUCK.... on a couple of OCCASION, did seen to see a small spark inside the small glass window,,, .... i googled this model, appears this tank may have problems, , yet no recall ? anyone have an opinion.
sfagtjt is offline   Reply With Quote
Old 05-09-2011, 09:10 AM   #2
BIGRED
Rewards Points: 252
All those new water heaters with the semi-sealed fire boxes have a problem. It's called GOVERNMENT do gooder restrictions. Prepare yourself for sticker shock and call A.O.Smith tech support to have them talk you through the relighting of your unit. They will need the model number and maybe the serial number that are on the data plate. Also clean around the heater very well; no paint cans, boxes, toys, tools, clothes, etc. and vacuum under and around the heater very well -no dust or dust bunnies under the unit, no wood or paint or drywall dust around the unit of any kind, almost as in sterile. Then call their tech support. There is an air shutter and a ceramic fixture on the bottom of the firebox that is sensitive to almost everything flammable that can trip and shut off all incoming air for the flame. Besides that if the spark ignitor, or thermocouple go bad the entire firebox assembly has to be replaced; not just the bad item AND on the ones we were installing back when this all started that firebox cost almost a third of the price for a new heater. It's supposed to be for our safety, but my first heater lasted 27 years and I only changed it because we needed a little more capacity. My second heater has been in for 11 years and is still working perfectly without any messing with it.
Grampa Bud is offline   Reply With Quote
A O SMITH gas water heater problem joeyuk Plumbing 62 01-24-2013 11:31 AM
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
