Old 07-21-2009, 03:59 PM   #1
AO Smith "new" Water Heater - what is the "R" value?
Read to purchase a new 50 gallon AO Smith (gas) Promax Powervent Water heater but unclear about various models and what "r" value ? Think it is the insulation factor? Getting variety or price quotes from plumbers - but wonder if "r" value impacts price - - - hard to compare apples to apples unless I get specific Model Numbers since there appear to be a few for the 50 gallon product. Can anyone enlighten me as also, is there a big difference between an R=8, R=16 or R=12 (and will that impact price?)
Lesdeak is offline   Reply With Quote
Old 07-23-2009, 08:43 AM   #2
R value refers to the insulation between the tank and the outer shell. Yes, a higher R-value will mean a more expensive heater, all other things being equal since the layer of insulation is thin, like one inch, and high R-value materials (foam) for that thickness cost more.
I don't have any figures on how long it takes the tankful of water to cool down (and then require re-heating) for a given R-value.
There are usually metal fins in the central flue that capture additional heat from the exhaust gases to heat the water from inside. But when the burner shuts off, air continues to flow up the middle and cool down the water. The most modern gas water heaters also have a flue damper to stop air from rising through the middle. This is also an added cost component.
If your heater has a low R-value, you you may be able to add a blanket of insulation yourself. Some restrictions apply for non-electric heaters as the blanket must be non-combustible and not block the flow of oxygen.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Tags
ao smith, powervent, r value, water heater
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
Water Heater tsmith Plumbing 10 12-01-2008 07:24 PM
Water Heater Troubles deadguydrew Plumbing 9 10-19-2008 10:30 AM
