Old 12-09-2010, 10:09 AM   #1
AO Smith GPSH water heater in System Lockout mode but resets itself
My AO Smith water heater goes into lockout mode after someone uses the shower or bath. At first it functions regularly then it starts to ignite again 3 times then goes into lock out mode...after several minutes the water heater resets itself and functions properly until someone uses the bath or shower again...not sure if it's related to how long the shower or bath is used for. It ignites well...I have tried cleaning the ignitor once but did not do it with a emery cloth or sandpaper...not sure. Thanks
gpatalin is offline   Reply With Quote
should I switch from natural gas to electric water heater supermaxhd Plumbing 24 11-28-2010 01:11 PM
How to flush water heater that has solar panels Homerepairguy Plumbing 2 11-11-2010 09:26 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
