AO Smith GPSH Water Heater In System Lockout Mode - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2012, 09:07 AM   #16
Thanks so much for the info. This worked perfectly. My wife is very happy that we had to spare a Saturday service call to tech. Saved $$$!!!
boshjales is offline   Reply With Quote
Old 06-26-2012, 09:25 PM   #17
I will try you fix tomorrow my water heater did the same 4 years ago but fix it by him self. so this time I will try your fix thanks for posting this.
Originally Posted by Abs777 View Post
I found out what it was. It was a dirty Flame sensor. I guess it was thinking that there wasn't a flame \wasn't getting gas and kicking itself off. I unplugged the water heater, pulled the bottom plate off (1 screw, undid the gas line (turn off the gas first), and pulled out the burner assembly. I then took sand paper and cleaned the flame sensor, put everything back together and boom HOT WATER. It was less than 20 minutes and saved me at least $100. The flame sensor looks like this (on the right) if anyone finds this thread in the future.
Thanks for the help.
Maxun is offline   Reply With Quote
Old 08-23-2012, 11:18 PM   #18
Big thanks
Water heater had the same problem. System lockout.
cleaned the sensor and vaccummed the unit for the dust.
Worked like a charm. Big Thanks Again
balsuu is offline   Reply With Quote
Old 12-21-2012, 01:43 PM   #19
Rewards Points: 195
Just in time for Christmas...My A.O. Smith Pro Max High Recovery 50 gallon tank, built in March 2008, is not heating water. The pilot is not out. It seems to kick on and off. Water is a balmy (ha) 80 degrees at faucets. My heating contractor has been here and is ordering a gas limiter valve. It won't arrive until the 26th; five days. Would the above instructions work? The plastic dust covers at the bottom of the heater were not very dirty. I haven't pulled any other covers off. My three teenagers are getting ripe. Anyone?
Arlo is offline   Reply With Quote
Old 01-24-2014, 09:16 PM   #20
Thank You Abs777
Hope you're still active on this site and just wanted to say thanks. Just finished completing your cleaning steps and "Bam!" Hot water with no successive start-ups and shut-downs. If you were in WI I'd so buy you a drink. Thanks again.
topspin64 is offline   Reply With Quote
Old 01-29-2014, 11:41 AM   #21
Rewards Points: 150
Glad it was of help...and Thank you!
Abs777 is offline   Reply With Quote
Old 05-04-2014, 10:04 PM   #22
Talking
Thank you!!!!
This worked like a charm! We've been fighting with having to reset the water heater for a week until today when it just wouldn't reset. Husband was online looking up new hot water heaters when I found your thread. I had him try it....it's working great. Except now he's mad he can't buy a tankless Thanks for saving us some $$$
dhamann48623 is offline   Reply With Quote
Old 09-01-2014, 02:02 PM   #23
more appreciation
@abs777 - Had same problem. In the years since the original post my ignitor (now ceramic) / sensor looked like this (attached). I removed (two screws total one for access plate one for ignitor/sensor assembly --- did NOT have to disconnect gas lines), cleaned both (maybe a mistake with the ignitor) with 00 steel wool, reinserted and fired up. Hot water now.
willing to try is offline   Reply With Quote
The Following User Says Thank You to willing to try For This Useful Post:
cobra617 (10-02-2014)
Old 09-01-2014, 02:42 PM   #24
Rewards Points: 948
I came here for this exact problem! Wouldn't turn on and showed a lockout code. I turned it off and back on and it seems to be fine now.
We had a one minute power outage just before it happened, but that might have been a coincidence.
Should I clean it or leave it alone? (Assuming it stays better...)
If I clean it, with steel wool, sandpaper, vacuum?
Toller is offline   Reply With Quote
Old 09-01-2014, 03:31 PM   #25
An old Tradesmen
Rewards Points: 6,112
Steel wool for flame sensor. Don't touch the HSI.
Old 10-02-2014, 08:29 PM   #26
Rewards Points: 4
I have the same ignitor/sensor as this one. I was in a foul mood because this hot water heater has been a pain for a few years.
I didn't remove the ignitor/sensor. I reached in with a small piece of 2000 grit sandpaper (what I had handy in my toolbox, I was too lazy to go looking for lower grit) and VERY lightly hit the top and bottom of that sensor. (I wasn't sure what I was supposed to sand so I very lightly did both). I only went 2-3 passes as I get nervous working with gas. (Electrical/Plumbing/Carpentry I can handle, but gas makes me nervous)
Put it back together, the unit fired up, ignited and stayed lit.
My question. Is this good? Or should I replace that ignitor/sensor assembly?
Also, I might sand it a bit more later on as I wasn't sure what I was supposed to sand and I went so lightly over both the ignitor and sensor that I can't imagine I did much.
BTW....THANKS!!!!! I was so peeved, and with the issues I've had with this unit, I was just going to bag it and have it replaced.
cobra617 is offline   Reply With Quote
Old 05-30-2015, 09:52 PM   #27
Rewards Points: 2
I also had this EXACT SAME ISSUE!!! Registered just to say thank you and to hopefully help others!
My hotwater tank model = GPSH 50 200
The sequence worked like this...
1. Blower activated...
2. Heating element activated...
3. Gas valve turned on...
4. Flame produced...
5. Flame went out after a few seconds
Thus no hot water for me, my wife, and two little ones.
I figured there must be some type of sensor that was an issue. I'm an IT guy not a HVAC/Plumber so I'm no expert!
The posts above (especially the picture!) showed me where the sensor was.
He is what I did to fix it.
1. Turned off the gas
2. Turned off the blower motor (there is a toggle switch on it. Just flip it.).
3. Turned off the power to the blower at the breaker
4. Opened the door at the bottom of the tank. You just need to remove 1 screw.
5. Sandpapered the dickens out of that thing in the picture in the post above...
6. Unleashed the vacuum on it...
7. Sandpapered it again for good measure...
8. Unleashed the vacuum again...
9. Put the door back on
10. Turned on the gas
11. Turned on the power to the blower at the breaker
12. Turned on the blower motor
MANY THANKS AGAIN FOR POSTING!!!!
THANKYOU!!! is offline   Reply With Quote
Old 05-30-2015, 10:51 PM   #28
Rewards Points: 42
You should'nt use sand paper. It'll cause quick fouling of the sensor. I use a file or steel wool. Otherwise it works until it becomes so fragile that it falls apart.
supers05 is online now   Reply With Quote
Old 07-30-2015, 12:24 AM   #29
Rewards Points: 2
9 pm tonight - no hot water. checked online, found this forum- pulled the flame sensor, cleaned it, popped it in and hot water 30 minutes later. thank you Abs777 for the post.
9918939 is offline   Reply With Quote
Desiging a manifold water system? BowDown Plumbing 1 07-20-2009 12:00 PM
Stumped. Water heater woes. bigcaddy Plumbing 35 06-14-2009 06:12 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
