Ao Smith Build Date - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2010, 02:51 PM   #1
Ao smith build date
How do you tell the build date on an ao smith gas water heater
i have a serial number of
mk99-0058325-246
clubkew is offline   Reply With Quote
Old 11-06-2010, 02:58 PM   #2
Chicago, IL
Michael Thomas's Avatar
AO Smith has a confusing collection of numbering methods:
If two letters first, next two numbers are year.
If one letter first, followed by two numbers and another letter, next two numbers are year.
If one letter first, next two numbers are year, providing no letter follows.
If two numbers first, this is year
So for yours:
mk99-0058325-246 = 1999
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-06-2010, 03:23 PM   #3
thank you
But how do you determine the month and day?
When searching for a part it requires a build date mm/dd/yyyy
Old 11-06-2010, 05:21 PM   #4
Chicago, IL
I've never seen a capacity plate which listed the day of manufacture, often they do not even list the month.
Old 11-06-2010, 06:03 PM   #5
build date
Hi Thanks again but I've looked at a few ao smith water heaters at friends and they all have a serial number and a build date, mm,dd,yyyy on the sticker. However mine is a bit older and don't have the build date listed as such but seem to think it's in the coding of the serial number. Read somewhere they use letters to denote the month A-M excluding I so an A would mean January but can't seem to figure the date out.
Weh I try to locate a part as waterheaterparts.com they insist on having a build date along with the model number to locate parts for the unit.
Thanks again
Old 11-06-2010, 08:48 PM   #6
concretemasonry's Avatar
Rewards Points: 2,654
The build date does really not mean that much.
After it is built, it goes to a distributor's warehouse than to a dealers warehouse.
The installation date in really the critical date, because 4 year old heater stored in a warehouse is just as good as a one day old heater IF it is the same model. - I have seen 3 year old heaters installed in new homes that were never used.
Dick
concretemasonry is offline   Reply With Quote
Old 11-06-2010, 09:26 PM   #7
Chicago, IL
Just checked, AO Smith is indeed now putting a full built date on the plate (I believed you, I was just trying to determine when they started). That's pretty unusual, Rheem for example uses mm/yy, and may others encode it in the SN and don't list the date information in a conventional date format.
Old 11-06-2010, 09:39 PM   #8
Homerepairguy's Avatar
Rewards Points: 998
i have a serial number of mk99-0058325-246
Regarding the month and day, if all else fails, "maybe" the ending 246 is the julian date. If it is, then 246 = September 3rd.
Homerepairguy is offline   Reply With Quote
Build a deck/carport jaums Building & Construction 1 08-31-2010 01:33 AM
time to build simple addition bmt1970 Building & Construction 9 03-05-2010 02:06 PM
Build or buy a shed and costs? Piedmont Building & Construction 7 05-19-2009 07:13 PM
To Build or Not To Build scoby1978 General DIY Discussions 6 05-27-2007 04:39 PM
