Anyway To Patch A Leak While It's Leaking? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2012, 07:50 PM   #1
Rewards Points: 264
Anyway to patch a leak while it's leaking?
I have a plastic hose barb thats drilled into a plastic bucket and sealed with silicone calking. The silicone failed and there is now a very slow leak (5 or so drops a minute). Problem is, anything I try to patch it (RTV silicone, plumbers putty, electric tape) just gets pushed out by the water, or doesn't bold because it's wet.
Is there anything I can stick on it that will either set instantly or be so thick it will plug the leak? Like maybe roofing tar? Or some kind of super-silicone?
Thought about using hot-glue -- problem is there aren't maybe things that bond to smooth plastic and silicone. TBH, I only know of one thing that does - silicone, and apparently not very well.
tibberous is offline   Reply With Quote
Old 11-10-2012, 07:52 PM   #2
Rewards Points: 54
Have you seen that rubber spray stuff seen on tv? Supposively works on wet stuff? Also found at big box stores.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 11-10-2012, 07:55 PM   #3
Rewards Points: 13,446
What is this bucket for?
You need what's called a bulk head fitting, just threading into thin plactic as you found out is never going to work.
http://www.bing.com/images/search?q=...ings&FORM=IGRE
Old 11-10-2012, 08:10 PM   #4
Rewards Points: 264
It works with silicone, it's just finicky - if you drill a bad hole or get a bad silicone ring you basically need to start over with a new bucket and hose, because you can't pull the hose off the barb without cutting it.
BH valves are going to be better of course, but there way more expensive. 2 hose barbs, a bucket, and 8in of vinyl tubing is like 6 bucks if you buy the tubing in 50 foot sections.
Old 11-10-2012, 08:18 PM   #5
It's a fitting not a valve.
My mistake I thought you wanted to no how to fix it right and not have to ever mess with it again.
Old 11-10-2012, 09:32 PM   #6
Rewards Points: 264
Nope, just want to make my floor less wet until I can take it apart and actually fix it. Hoped they'd be some old redneck trick, maybe there isn't :/
Old 11-11-2012, 07:26 AM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,012
Nope, there ain't....
the only thing that sicks to sillycone, is more sillycone...
Old 11-11-2012, 09:34 AM   #8
Rewards Points: 988
The old red neck trick is to quit ruining a good bucket and siphon the water out the top. It's worked ever since gravity was invented . To stop or regulate the flow put a stopper in the discharge end of the siphon hose. In my desert region I often water plants using the drip irrigation siphon method .
You can still use that bucket with the hole by removing all that stuff and put a piece of duct tape over the hole on the inside after cleaning that area .
SeniorSitizen is offline   Reply With Quote
Second leak in main from the meter JoeColeman Plumbing 7 08-14-2012 09:05 PM
Leak That Stopped Leaking? nullqwerty Plumbing 8 01-28-2011 07:39 PM
leak leak leak dongdong1 Building & Construction 4 01-11-2011 09:21 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 01:26 PM
