Anyone Use Shark Bite? Good ? Bad? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2008, 07:16 PM   #1
Rewards Points: 150
Anyone use Shark Bite? Good ? Bad?
I saw a new item called Shark Bite in the plumbing section at Home Depot. I was wondering if anyone has used it and how well it works. I have to redo some plumbing coming up and thought about using it.
twilightcall is offline   Reply With Quote
Old 01-03-2008, 08:00 PM   #2
I haven't used them yet, but this website sure lists a bunch of them!
Steve
lockeplumbing.com/catalog.asp?c=Pipe%20And%20Fittings&s=Shark%20Bite
stp57 is offline   Reply With Quote
Old 01-03-2008, 09:58 PM   #3
Sharkbites work good for emergencies and oddball situations, I keep an assortment on the truck for that reason. They might be a little expensive for a bigger job though.
scrapiron is offline   Reply With Quote
Old 01-03-2008, 10:04 PM   #4
remodeling pro
I have used them for temporary stuff, like capping off lines during renovation work, and they worked great. Don't have any experience in the long term with them. Can't beat a soldered joint for permanent stuff IMO.
troubleseeker is offline   Reply With Quote
Old 01-11-2008, 05:58 PM   #5
Anyone use Shark Bite? Good? Bad?
I have an outdoor faucet and the line runs 16' through a crawl space and about every 8 years I procrastinate shutting off the supply valve....and yup last year it froze and opened in two spots...There was enough slack in the copper line to cut the two spots out and rather than use a torch against floor joists (which I have done in the past - especially tough to do on your back) I decided to try the Shark Bite unions on the two joints and I have to tell you they were easy to use and I was duly impressed - I believe thay are rated to 200psi......they were extremely easy to use....push together and you are done....They have been in place for the past year with no leaks....
FYI....
Rick
Rick Bruner is offline   Reply With Quote
Old 01-11-2008, 06:08 PM   #6
Send a message via AIM to Marlin
I believe they are allowed in the UPC. They are however very expensive and it's obvious it was a DIY when you see them.
Marlin is offline   Reply With Quote
Old 01-11-2008, 09:15 PM   #7
yea i use them in my basement for a sink. they are working great so far, no problems.
bobcatnj is offline   Reply With Quote
Old 01-12-2008, 11:51 AM   #8
Bathtub Refinisher
They are easy to use and work well. I only use them for repair though. For permanent repair get out the torch and solder the joints.
Mike
tubguy is offline   Reply With Quote
Old 01-14-2008, 07:32 PM   #9
I have used them for temp repairs...they are ok for code in europe, I am told...I would rather solder in the wall...
TR777 is offline   Reply With Quote
Old 01-14-2008, 09:05 PM   #10
Journeyman Plumber
Ron The Plumber's Avatar
Just remember, they relay on a o-ring for the seal, and just like the seals in a toilet tank, they can deteriorate over a long period of time, so if you use them don't bury them in walls, cause you never know.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 76 05-14-2015 10:23 PM
Looks like a good Christmas this year! leroyme Off Topic 6 12-23-2007 11:45 AM
plumbers shark bite fittings jburkeg Plumbing 9 11-12-2007 11:29 AM
Good inexpensive 10" miter saw for a DIY'ER??/ Sellncars Tools 19 09-26-2006 01:17 PM
