Old 12-23-2007, 08:56 PM   #16
Anyone use PEX to plumb an entire home?
Whole house in new construction in Fla. is the norm now.
It is almost a requirment in areas that have gone to reverse osmosis water treatment because that water can eat up copper pipes.
I did 3 patchs in my copper pipes last winter with pex. The supply house guy said he does a "re-pipe" job a week in the Ft Myres area.
kbs2244 is offline   Reply With Quote
Old 12-24-2007, 01:17 AM   #17
KBS, you are saying that the water is so bad that it wears the copper pipes or the osmosis requirement wears the pipes?
scott.martin is offline   Reply With Quote
Old 12-24-2007, 11:09 AM   #18
It seems to happen more on horizonal runs than vertical.
What you will see is a spot on the pipe where the water just oozes through. The copper turns sponglike there.
It is very unperdicable. The water is reacting to some kind of small deposit in the copper.
On the outside you will see the typical green stain. But if you look inside the cut out piece you will see a fuzzy growth of some kind. Almost looks like a catipiller.
RO does some kind of chemical change in the water that finds these disposits in the copper that non treated water never knew was there.
I used PEX and Shark Bites to patch mine. But now I am a nervious guy.
I watch the celing for soft spots and turn off the main valve and drain the system if I am gone more than a day.
I cann't afford a re-pipe right now.
Old 12-24-2007, 11:48 AM   #19
That is very interesting. The good thing is the main supply from the city or main water source can remain copper coming into the house, but everything after that could be PEX. And I hear you on not being able to re-pipe, I am a dumb enlisted guy, so cash doesn't come pouring in. Thanks KBS
Old 12-25-2007, 11:42 AM   #20
Something I left out that may be of intrest to everybody.
My Fla place is a 4th floor condo, top floor, so I don't have to worry about bad pipes above me.
But I am liable if my pipes cause damage below me. And most inportant, my insurance no longer covers damage caused by bad pipes.
This is enough of a problem that the insurance cos have quietly dropped covering damage caused by piping from their policies.
I think Fla law says the pipes in a cond building are common property up the the main shuttoff valve for the unit. But anything after that is the unit owners responsibilty and liability.
If any of you are condo owners in an area that has gone to RO water treatment this is something to check out.
And if you are on a condo board you should check your coverage for the piping in the common area.
Old 12-25-2007, 12:23 PM   #21
pex is a good product as long as the type you chose is alowed by the plumbing code. if its not allowed you will have a problem.
if it is a approved materal and installed as per the instructions. no problem. here we use the uniform plumbing code and pex pipe has to be stamped with astm f876/f877 and the fittings are astm 1807. the fittings look like the ones used for poly pipe. but if you use the ones not listed they will blow apart.
this what we are useing in the asu dorm rooms
http://na.rehau.com/construction/hea...plumbing.shtml
ranman469 is offline   Reply With Quote
Old 12-25-2007, 01:47 PM   #22
ranman, are you saying that if I don't use the ones listed as "astm 1807" then they will blow apart? or are you saying if I don't use the ones approved for the REHAU PEX then they will blow appart if they are a different brand?
Old 12-25-2007, 03:06 PM   #23
sorry scott
i`m saying use only ones listed and approved by your local codes. i would check with the local plumbing inspector for the current approved products.
you also can check with a plumbing supply shop.
the bad thing zurn pex fittings are listed as approved in the UPC and IPC code books, but there is a recall on zurn pex fittings , for them breaking
More On This Topic
Hi, I'm Jeremy Blackwell I'm here today to help you get started on your basement remodel project. This is a GFCI outlet that's required in bathrooms. The reason this is required is because if any water were to just drip on the outlet or if a hair dryer... Read More »
This area used to be a back porch where the ceiling drops down. This entire area was a back porch. This end segment of it was a laundry room. When we decided to make this an entry alcove, what we did was we had to end the plumbing here, we had to... Read More »
Hi im doug. I work with tewenty great guys in st. louis at doug jenkins custom hotrods and were gonna do some work for you today on expert village. This is a 1967 camaro convertible rs ss getting a new exhaust system. We performed a frame off restoration... Read More »
Hi, I'm Shaun Schaefer on behalf of Expert Village and today we are going to be learning how to play a few basic flam rudiments. Now that we have our cheat sheet drawn of our 1 bar of music of the rudiment of the pata fla fla. Let's go ahead and pick up... Read More »
How to Winterize a Hot Tub
How to Winterize a Hot Tub by Expert Village
OK, here we're going to talk about how to winterize a spa. A lot of people enjoying using their spa in the winter but for those of you that are not going to be around the spa in the winter time, it's very important to that we evacuate all the water out... Read More »
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
