Anyone Thats Online Please Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2010, 06:37 AM   #1
Send a message via MSN to RubyRose66
Unhappy
Anyone thats online Please help
I'm having some issue due to the cold weather. I live in a mobile home and I have no water at all.
I have decided to turn the water supply off to the home and also turn off the current to the water heater.
Is that a bad thing or ok to do so.
Please, I am unable to find any answer if this is ok or not.
-RubyRose
I thought this was an instant chat room
RubyRose66 is offline   Reply With Quote
Old 01-09-2010, 07:34 AM   #2
Yes it's OK.
Why did you decide to turn off the water and hot water heater??
What's the temperature there? Is it freezing?? Is that why?
SULTINI is offline   Reply With Quote
Old 01-09-2010, 07:38 AM   #3
Remodeling Contractor
Unless the water heater had no water in it... leave it on. Or it may freeze is crack the tank. Turning off the water is okay, but there is no reason to do so. Do you have a complete skirt around the home with no breaks in it? If not this caused your problem. But this weather is colder than normal (Must be that global warming thing!)
Old 01-09-2010, 07:45 AM   #4
If the answer to one of my questions is , yes it's freezing then leave the water heater on as Bob said.
Old 01-09-2010, 08:59 AM   #5
Rewards Points: 27
If you are afraid of freezing, you are best off to leave it on and let your faucets drip, running water, even a drip will help keep your pipes from freezing.
diykc is offline   Reply With Quote
Old 01-09-2010, 09:26 AM   #6
Licensed Master Plumber
Leave the water heater on
Climb under the home and see if the heat tape is plugged in or, is bad. Either way, fix the heat tape and wait fir it to thaw out.
NHMaster is offline   Reply With Quote
Old 01-09-2010, 09:45 AM   #7
Its now 827am
I decide to turn the water supply off to the home because I don't know better...I did it because I heard water continously running at the water tank which was the hot line (felt the line) then I felt the cold line and nothing. Soooo, I thought since there was no water in the house I will shut the supply and the current (at breaker box) to water heater.
One more thing - As soon as I shut the water supply and then heard at the waterheater possibly water/break below the floor.
I'm fixing to look and see what the damage is, if any...(crossfingers).
BTW: Since I shut water supply to all of the house and current to the water heater. I thought I leave it off and let it thaw out and I am going to drain if all possible, the tank.
I have been up all night worried and searching for advice.
Please give me advice.
I am on MS Messenger (randers3@hotmail.com) for any quick advice.
Old 01-09-2010, 09:57 AM   #8
NHMaser: Heat Tape
There is areas that are not insulated from where I can see. This is a rented older mobile home (1rst time to live in one) the landlords are not going to fix or put any money into it. I need to take care of this on my own.
Question? if I need to thaw out an area underneath the mobile ---what exactly needs to be thawed out first?
Old 01-09-2010, 10:00 AM   #9
Rewards Points: 150
If it is frozen, you need to get some heat under your home. A space heater could work, I use a salamander. Be careful doing this!!
user69544 is offline   Reply With Quote
Old 01-09-2010, 10:06 AM   #10
Driller, Do you have MSN Messenger or Yahoo? At the moment I am needing instant communication oppose to refreshing forum for any replies.
randers3@hotmail.com is my MSN Messenger.
Old 01-09-2010, 10:09 AM   #11
BTW: I thought of actually getting my heat blower (commercial) but I don't know. I need advice on that thought too.
Oh what a nightmare of worries.
-Rose
Last edited by RubyRose66; 01-09-2010 at 10:11 AM. Reason: Adding to Driller - reply of heat fan for thawing pipes
Old 01-09-2010, 10:09 AM   #12
A landlord IS required to fix a problem where you do not have any water
Contact your local heath Dept
That's what we had to do renting an Apt once
Old 01-09-2010, 10:31 AM   #13
Scuba_ Dave,
I understand about obligations but I am renting this from a friend whom I made the agreement. At the moment I need to take care of this.
A handshake still counts for something to me and when I shake on it, there is no turning back on the deal I made. Learn and move on. So at the moment I need some sound advice.
Old 01-09-2010, 10:37 AM   #14
Tunr the water back on & look under the mobile home & look/listen for water rushing
If you hear that sound then a pipe is broken
Turn the water back off & call a plumber to fix the pipes
If you do not hear water running then leave the water on
Have you used any hot water since the pipes froze?
If not the WH still has water in it - but I would leave off for now
Turn a cold water tap on slightly
You then need to go under the trailer with a heater, blow dryer etc to warm the pipes up
Heat wrap tape would be a great idea too
Make sure anything you use is plugged into a GFCI protected outlet
If under the mobile home is not enclosed you will not be able to get the area warm
Instead you need to direct the heater(s) at the pipes
Old 01-09-2010, 08:14 PM   #15
Fixed cracked broken pipe
7pm Sat.
Finished (630p)for the most part replacing the 1/2" CPVC cracked/ broken pipe.
Everytime we thought we had cut out the bad part..we had to start over again after checking it with flowing water.
This was tiring. Hopeful that its solved thou.
Temp is (11) for the lows again tonight.
Online Nursery Recommendations? jkrodger Landscaping & Lawn Care 12 03-26-2009 07:16 PM
online code book ponch37300 Electrical 3 01-26-2009 09:06 PM
buy cheap bathroomtile online? rramirez General DIY Discussions 2 11-11-2008 02:09 PM
