Anyone Removed A Water Heater Top? -- Anode/Outlet Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2010, 03:06 PM   #1
Anyone removed a water heater top? -- Anode/Outlet Replacement
I have a Bradford-White water heater that has the anode integrated into the hot-water outlet.
I bought a new anode and was about to replace it. My problem is that the outlet appears to screw into the tank and the tank is just below a thin lid that covers the top of the water heater. My fear is that if I cannot see the junction between the outlet and the tank, I will not be able to see if there is a small leak.
Has anyone managed to remove top of a regular water heater? It looked easy, but my lid doesn't seem to come off. I can't tell if it is just binding against the existing hot and cold outlet/inlet pipes, or if it there is something else holding it in.
gadha is offline   Reply With Quote
Old 04-17-2010, 03:56 PM   #2
Rewards Points: 1,452
If you unscrew the hot water nipple from the tank using a Stillson wrench (pipe wrench) will the old anode rod come out with it?
Letting you insert the replacement anode?
Without having to disassemble the water heater outer shell?
AllanJ is online now   Reply With Quote
Tags
anode water heater lid
Water heater burst - musty odor in wall! Tiny_J General DIY Discussions 10 02-18-2010 02:27 PM
Bradford White water heater adpanko Plumbing 0 02-10-2010 04:33 PM
Stumped. Water heater woes. bigcaddy Plumbing 35 06-14-2009 06:12 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
