Anyone Know What This Plumbing Item Is... - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-19-2009, 09:43 PM   #1
Rivethead is offline   Reply With Quote
Old 04-19-2009, 10:10 PM   #2
Tired & Dirty
Rewards Points: 83
Me thinks it is a small box with an X in it.
evapman is offline   Reply With Quote
Old 04-19-2009, 10:22 PM   #3
joed's Avatar
Rewards Points: 11,576
Yup box with a red x. If you want to post a picture you need to post it at a site that allow direct linking not one that requires you to log in.
Old 04-20-2009, 05:38 AM   #4
Old 04-20-2009, 05:44 AM   #5
I'll try this again... sorry about the previous photo problem.. and this one too if I screw it up...
Old 04-20-2009, 06:51 AM   #6
My guess would be a automatic shutoff in the event of an open line???? The long gadget below is a pressure or flow monitor, not sure about the thing with all the wires, an shutoff valve??
Old 04-20-2009, 08:48 AM   #7
Tired & Dirty
Rewards Points: 83
I agree with Bill, looks to be a shut off of some kind to me, need some more pics of the sides and back maybe.
Was just giving ya a hard time about the X in box thing, posting pics can be a real pain sometimes.
Old 04-20-2009, 09:26 AM   #8
joed's Avatar
Is this on the water supply to the house? It looks like it might be part of a hydronic heating system. It could be a zone valve to shut off that zone. It could be a whole house shutoff in case of a leak.
Old 04-20-2009, 10:21 AM   #9
Drywall contractor
Rewards Points: 1,070
Looks kinda scary whatever it is...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-20-2009, 11:01 AM   #10
Rewards Points: 5,336
Where do all the wires go?
Ron
Old 04-20-2009, 06:15 PM   #11
The thing is on the incoming supply line - so you see it right after the pressure regulator. The wires are unhooked and just left in place on the stud - where they went would have helped I know.
Stumped me.... I suppose it may end up being one of those mysteries but it sure had me curious...
Old 04-20-2009, 07:54 PM   #12
I will guess.
The round thing looks like a solonoid valve. Does the black thing have two wires coming out of it?
The box installed on the skinny pipes is probably a pressure gauge.
I am thinking that, when wired up and turned on, the pressure gauge would sense a drop in pressure and activate the solonoid valve to shut off the water.
220/221 is offline   Reply With Quote
Old 04-20-2009, 09:24 PM   #13
Three wire out of the box which has air tubes on it also. The grey wire is just hanging down - looks like it hooked in where you see the wire nuts.
I'm thinking the guess about some auto shut off is right....
Old 04-21-2009, 07:41 AM   #14
Since you're asking I'm guessing you didn't install it so this won't hurt your feelings, but it looks like a rats nest of wiring with a stem that could snap off too easily so protect it but leave it accessable.
I would tidy up and twist that wiring where the blue connectors are and pull that wire at least 6" back above if possible from any pipe connections then clamp with a nylon cable tie, not tape. Wires look like low v signal wiring perhaps to an external sensor?????
Chemist1961 is offline   Reply With Quote
Want to tile bathroom - raise plumbing? wombosi Plumbing 2 11-13-2008 08:54 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 04:04 PM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 08:37 PM
Connecting new plumbing into existing plumbing Just do it guy Plumbing 2 02-18-2008 10:36 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 12:14 PM
