Anybody Recognize These Valves???? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-12-2009, 11:49 AM   #1
Anybody recognize these valves????
Hate to ask working on a home radiant heat system and ran across these older zone valves. the middle turns endlessly and the outer nut tightens and loosens. I dont want to sit here all day with the furnace on feeling and adjusting pipes
jethrobodean is offline   Reply With Quote
Old 11-12-2009, 11:53 AM   #2
I believe they're flow control valves. The slot is oriented in the same direction as the valve damper. What exactly is the question?
jerryh3 is offline   Reply With Quote
Old 11-12-2009, 12:15 PM   #3
I am trying to adjust the heat flow to different rooms. I have 11 of these operating off one pump. I had to burb the system today and I was playing with these valves trying to shut off flow. with all off them in the 9-3 o'clock position, with the nuts tight, I wasn't able to stop the flow threw the system. I assumed that they were flow controls but didnt quite understand the locking nut. So all the control is just within 1/4 turn of the screw? Full on is at the 12-6 o"clock position? I have to find where I want it set then tighten the lock nut? thanks for your help. JET
Old 11-12-2009, 12:23 PM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
My guess also is that they are flow control valves but with a needle instead of a gate. Did you try turning clockwise until it stops?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 11-12-2009, 12:41 PM   #5
yes the middle turns endlessly both cw/ccw. I can screw the lock nut off and the middle wont come out.
Old 11-12-2009, 04:08 PM   #6
How do you know they're not stopping the flow in the horizontal position?
Old 11-12-2009, 04:26 PM   #7
I have 3 zonepumps in my house. While purging the system of air I can block off the two other zones and run water directly through one zone at a time. Running water through this zone with these 11 valve controls the water will keep a flowing no matter if I have all the zones horizontal or in the vertical position. With the other zones closed off before they feed into the furnace I should be able to shut the water completely off. But I can't. When the heating system is on, I can tell a difference between the horizontal position and the vertical on position by the heat flowing through the pipes
Old 11-12-2009, 04:47 PM   #8
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
apparently they are working, to some extent then.
These are balancing valves and are not intended to serve the same purpose as a zone valve so maybe they are not intended to seal completely.
I could not find anything stating whether they should seal or not or are simply intended to offer varying resistance to flow.
Is there any sort of manufacturers markings/identification on them?
Old 12-07-2009, 02:56 PM   #9
I'm sure they aren't dial temperature gages, but they look just like ours...before the gage went in. Can you get a picture from the side?
Cecosugi is offline   Reply With Quote
Tags
how do they work?
shutoff valves all leaking hohadcr Plumbing 1 08-01-2009 06:38 AM
pex valves rtoni Plumbing 2 02-24-2009 03:34 PM
why do my 1/4 turn valves leak? moondog111 Plumbing 1 12-07-2008 11:09 PM
leaking valves - DIY help wombosi Plumbing 4 11-17-2008 08:32 PM
shut off valves on cast iron radiators bdw2677 Plumbing 2 10-21-2008 07:07 PM
