Old 03-05-2012, 11:12 AM   #1
Any way to put a 33" wide sink in a 38" wide hole?
We have a 33" stainless steel sink that we would like to replace our current sink but our current sink measures in at about 38" side to side. The front to back measurements and the depth of the smaller sink work, it is just the side to side measurement that we are short. Replacing counter is not an option at this time. We were wondering if there was some kind of metal strip that we could have placed on the sides of the 33" wide sink to make it work? Anyone ever heard or seen this done or have another idea to make the smaller sink work?
Thanks!
Natalie
Natalie559 is offline   Reply With Quote
Old 03-05-2012, 11:31 AM   #2
A friend said he would recommend cutting a piece of wood to fill the gap and laminate it with same color (if possible) or a contrasting color. Glue it in then brace it with a piece of wood underneath to keep it level and stable.
Hmmmmmm. . .
Old 03-05-2012, 12:38 PM   #3
Nope not going to work for many reasons.
Just find a new sink that's the size you need, there's thousands to choose from.
By the time you bought the new formica, glue, materials and tools to just just patch it you could have almost bought a new preformed top.
Old 03-05-2012, 12:48 PM   #4
It was a dark and stormy
Yoyizit's Avatar
(38-33)/2 = 2.5" wide wooden structural supports on each end. The volume of the sink will tell you how strong these need to be. Water weighs about 8 lbs/gal and 62 lbs/cu ft.
For the cosmetics and waterproofness of the sink surround I'd look for a shop that cuts plexiglas to your dimensioned drawing.
Old 03-05-2012, 08:02 PM   #5
first option find sink that fits or that is larger than whole
have a solid surface piece made that will sit on old counter with cut out for new sink and turn it into under mount route flutes into solid surface top to create a built in drainboard top
http://www.countertopsinc.com/corint...gralDrainboard
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Suspended/Floating sink installation? How? techprincesse Building & Construction 3 11-21-2010 04:05 PM
Cutting out a hole on a stainless steel sink...pics Goldglv General Discussion 14 02-28-2010 11:04 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
Sink hole under garage slab. diggitydog Building & Construction 3 08-31-2006 01:49 PM
