Any Trick To Soldering Pipes That Won't Dry - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-22-2011, 10:44 PM   #16
Rewards Points: 558
Any trick to soldering pipes that won't dry
Originally Posted by Akpsdvan View Post
There is one trick that an older plumber told me about years ago..
If the water is down to just a few drips and I mean a few drips every 2-3 minutes ... White bread... take the crust off and make a ball out of the white part... tight ball and then stuff it up the pipe 4-5" if one can and get the joint soldered. Then when the water is turned back on use a faucet that has the screen removed and wait... the water pressure and wet will move the bread down the line...
It might work... have not tried it my self... but have heard it from a number of older plumbers that I know.
it works. I did this many times...
epson is offline   Reply With Quote
Old 12-22-2011, 10:49 PM   #17
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Originally Posted by rjniles View Post
I have one of these:
Called a "Jet Swet". a space age version of the white bread trick.
http://www.brenelle.com/
I bought mine used on eBay.
jet sweat works good for replacing/sweaing in valves
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
oh'mike (12-22-2011)
Soldering Copper Pipes smata67 Plumbing 1 05-17-2010 05:21 PM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 12:20 PM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 09:10 AM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 10:03 PM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 02:18 PM
