Any Problem With Sink Pipes Off To Side? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-02-2012, 10:04 AM   #1
oops never mind
Hi all,
thanks!
petros151 is offline   Reply With Quote
Old 07-02-2012, 10:49 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,972
Sounds like a question I would ask.
I know of no reason why you can't. The only 'issue' is that you will need longer steel braided lines to go from you valves to the facet. But that is certainly not a big deal.
I certainly think it would be a lot easier to turn the water supply on and off that way. You have my vote.
Pipes too high & too extended for new sink install Sascia17 Plumbing 6 11-21-2011 07:46 PM
trying to install faucet, but old pipes causing problem 19mquinn79 Plumbing 5 08-15-2011 09:39 PM
Kitchen Sink Drain Problem Spark General DIY Discussions 9 06-14-2009 11:00 PM
Problem with garage door side entry thundercloud Carpentry 6 06-09-2009 06:27 AM
copper sink and standard drain pipes chefnmusic Plumbing 3 10-11-2008 08:18 AM
