Any Problem With Cold Water Branch Before Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-08-2011, 03:45 AM   #1
any problem with cold water branch before water heater?
we want to turn the tub in opposite direction and replumb. fyi: changing all galvanized piping to copper for enitre house. will be using 3/4" soldered copper until vertical lines for fixtures, which will then be 1/2" soldered copper.
all fixtures basement and first floor only.
waste drain for tub in new position will be in way of "lengthening" old cold water supply following current plumbing route. won't be a problem for hot supply route.
any reason that we should not branch off (with 3/4" t) main (cold) supply line to tub before supply line reaches water heater? old house, so approx 30-35 ft to water heater as it still vents into chimney.
currently, hose bibb t's off supply line before water heater, which will not change. that branches off after proposed tub branch, but of course, before water heater.
cold supply after water heater would be to laundry tub and washer (basement); kitchen sink; toilet and bathroom sink (all main floor). tub just happens to be much closer to front of house like water supply line coming in, just on opposite wall.
Any input greatly appreciated!
Jasper
jasperjodo is offline   Reply With Quote
Old 06-08-2011, 07:12 AM   #2
Not sure I understand your question. Branches are allowed anywhere in the line(hot or cold), it matters not where the heater is located. Hot and cold are seperate lines. Before the heater it is cold, after the heater ir is hot. And you are correct that all lines should be 3/4 as close to a fixture as possible.
Switching ends on the tub can be an issue for venting and drainage, but supply is not a problem.
Old 06-08-2011, 07:43 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
And your water pressure should substantially improve when you replace that old galvanized with the copper.
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-08-2011, 09:01 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 452
If water pressure is around 60-80psi it is not uncommon to supply 2 fixtures on a 1/2" line. Unless you will be installing a T/S valve with multiple heads and body sprays, 1/2" will do just fine.
Smelly brown water from water heater timthetoolman Plumbing 2 05-19-2011 10:32 AM
Pluming Hot Water Turning Cold - Help! kissiffer4 Off Topic 1 01-14-2010 06:00 PM
strange problem with hot and cold water globusa Plumbing 2 09-25-2009 10:46 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
