Any Plumbers Out There? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2009, 12:34 PM   #1
Rewards Points: 91
any plumbers out there?
if there are any plumbers out there that could take a quick look at these two pictures and post any comments.
The pictures are of copper piping for a shower I had put in yesterday. The pipes have gone in on a new wall, built Saturday, with 3/4" plywood attached to the joists, then the pipe anchored to the plywood and out through the bottom of the house into the crawl space. The close up shot shows the elbow snug up against the plywood and running down.
I'm about to install insulation and close up the wall in a few hours, before installing kerdi.
Any thoughts/feedback would be great before I close the wall. thanks very much!
mmhendrie is offline   Reply With Quote
Old 03-30-2009, 01:37 PM   #2
Remodeling Contractor
looks fine, but I can see the teflon tape is wrapped in the wrong direction.
Old 03-30-2009, 01:42 PM   #3
Rewards Points: 91
does that warrent a re-do? It doesn't appear to be leaking, but if it won't hold up, I will take it apart...
Old 03-30-2009, 01:47 PM   #4
It will work fine.
Old 03-30-2009, 01:59 PM   #5
RippySkippy's Avatar
just to be clear, you did a leak test? How long?
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 03-30-2009, 02:03 PM   #6
you mean for the 24 hours as an inspector will require? Also test with the water as hot as you can get it.
Old 03-30-2009, 02:06 PM   #7
Rewards Points: 91
well, i finished connecting everything around 10:30pm last night, and the water pressure was on all night - i'll probably start work around 7pm tonight on the walls, unless holding out for another couple of hours makes a different.
Obviously, the spout hasn't been running for that time, so in theory, the spouts only had a few seconds of testing - when I turned it on and off to test the water came out. Is there a way to do sustained testing of the spout?
Old 03-30-2009, 02:10 PM   #8
You are only testing for leaks, than this is done with air or water in the lines.
Old 03-30-2009, 02:16 PM   #9
Rewards Points: 91
ok well the waters been on for over 12hrs..so i think it must be ok
Old 03-30-2009, 02:31 PM   #10
Then assuming you have no leaks...and the valve is at the correct depth..you should be good to go. A friend did something similar said he leak tested...when the water came on it also came out. He had to hack up his new work...not a pretty sight....
LMASD
Old 03-30-2009, 02:35 PM   #11
Hmm.... A friend of mine.... seems we have heard that one before.
Old 03-30-2009, 02:38 PM   #12
Rewards Points: 91
yes, getting the valve at the right depth took a long time. In fact, most of the time was spent on prep work - measuring etc. I think i might attach the end to a flexible shower head and fill up a couple of buckets and just make sure there's no water from anywhere other then the shower head! but so far, so good...
Old 03-30-2009, 10:21 PM   #13
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Good grief, you're testing it to death! lol A 30 minute test is all that an inspector requires. You are DEFINITELY good to go. Cover it up, finish the project and enjoy.
JDC is offline   Reply With Quote
Old 03-31-2009, 09:03 AM   #14
Registered User
Termite's Avatar
Yeah, if at all!
Plumber's Putty around sink flange DIYGST Plumbing 6 02-03-2009 08:18 PM
New Forum for Professional Plumbers ... Only Nathan Plumbing 1 06-18-2008 12:44 AM
Shouldn't use plumber's putty on acrylic tubs?? jayp Plumbing 1 06-10-2008 11:03 AM
Clear silicone caulk used instead of plumber's putty**HELP** hummin40 Plumbing 8 02-12-2008 02:59 PM
plumbers shark bite fittings jburkeg Plumbing 9 11-12-2007 11:29 AM
