Any Issues Using Plastic Pex Fittings For Crimp? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-07-2013, 11:40 AM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Any issues using plastic pex fittings for crimp?
I have the crimp tool and I've done a bit of pex installs using brass fittings. I am wondering, can I also use the black plastic fittings with the crimp method? Or are those only for expansion method? Any advantages of either one?
Residential well water issues ..... low PH reelturner Plumbing 7 03-06-2012 07:02 PM
House settling issues gmvshort Building & Construction 3 02-22-2011 06:26 AM
Basement Sump Pump & Dimpled Plastic Membrane Interior Questions cloves Building & Construction 0 03-24-2010 09:44 PM
Plastic plywood, Plastic sheets, Plastic decking Spud Building & Construction 1 10-16-2009 04:43 AM
Plastic - using plastic to make your own replacement parts Hemingway General DIY Discussions 5 09-26-2009 07:49 AM
