Any Downsides To 6in Sewer Lateral? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-13-2012, 04:58 PM   #1
Any downsides to 6in sewer lateral?
I'm researching and spec'ing out the house I hope to build in a few years.
Now, I haven't checked with the city or even a plumber yet - I just wanted to float this idea by some experienced amateurs and possibly professionals on the forum here before investigating further.
Any thoughts on going with a 6in sewer lateral over 4in? That 6in diameter will probably extend a few feet above the basement floor on at least one drain stack. I know parts will be more expensive, and a backflow preventer has been harder to find, etc.
My primary reason for considering 6in is nothing more than "if 4in is good, 6in must be better!"
Thanks in advance!
cerfsud is offline   Reply With Quote
Old 05-13-2012, 11:00 PM   #2
You go too big and run the risk of not getting a proper scouring of the lateral drain when running water et al to the sewer. Sizing charts are there for a reason and based on decades of experience.
VIPlumber is offline   Reply With Quote
Old 05-14-2012, 08:45 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 562
Agreed. 4" will handle more fixtures then you could ever put in your house. For example, a 3" horizontal line will take up to 3 toilets per UPC...
Tags
drain , lateral , sewer
Back pitch sewer pipes and sewer smell..? HeatherJ Plumbing 15 04-23-2011 11:13 AM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 11:10 AM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Sewer Lateral replacement jkrodger Plumbing 2 07-17-2007 08:52 AM
