Any "baseboard' Heating That Installs On Wall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2011, 11:31 AM   #1
Rewards Points: 410
Any "baseboard' heating that installs on wall?
I have forced hot water baseboard heating. I've got a basement bathroom with no heating, and no available wall space at floor level I can install a baseboard. The main reason is because the wall space that's available a pocket door slides into so I can't install a baseboard heating system there. I don't want electric either, I pay $0.23 per kW.
The only space I see where I can tie into my current FHW system and add heating is above the toilet. I was thinking I'll just get a FHW towel warmer, it will heat the room and warm my towels but not a very convenient place to be hanging towels. Then I saw the cost ($250 for the cheapest). Do they make a wall mounted FHW something I can plumb into my heating system that will fit/go above the toilet? Thanks
Piedmont is offline   Reply With Quote
Old 01-21-2011, 01:57 PM   #2
Rewards Points: 1,452
A baseboard radiator can be installed at any height, although the circulation of warm air is less efficient if the baseboard is mounted really high and there is no ceiling fan.
A baseboard radiator that is not too squatty can be retrofitted with a U-turn (two elbows) and a non-finned pipe that goes under and back the other way so both inlet and outlet are at the same end of the unit. This may permit installing it in front of the pocket door pocket.
Old 01-21-2011, 06:05 PM   #3
Here is one manufacturer of units that would satisfy your requirements:
http://www.runtalnorthamerica.com/re...ors/index.html
Bob999 is offline   Reply With Quote
Wall construction for insulation support WillK Building & Construction 3 12-09-2010 02:55 PM
Gas wall heater not heating tonytom00 HVAC 1 11-04-2010 08:46 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 04:43 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
