-   -   Any "baseboard' heating that installs on wall? (http://www.diychatroom.com/f7/any-baseboard-heating-installs-wall-93008/)
Piedmont 01-21-2011 10:31 AM
I have forced hot water baseboard heating. I've got a basement bathroom with no heating, and no available wall space at floor level I can install a baseboard. The main reason is because the wall space that's available a pocket door slides into so I can't install a baseboard heating system there. I don't want electric either, I pay $0.23 per kW.
The only space I see where I can tie into my current FHW system and add heating is above the toilet. I was thinking I'll just get a FHW towel warmer, it will heat the room and warm my towels but not a very convenient place to be hanging towels. Then I saw the cost ($250 for the cheapest). Do they make a wall mounted FHW something I can plumb into my heating system that will fit/go above the toilet? Thanks
AllanJ 01-21-2011 12:57 PM
A baseboard radiator can be installed at any height, although the circulation of warm air is less efficient if the baseboard is mounted really high and there is no ceiling fan.
A baseboard radiator that is not too squatty can be retrofitted with a U-turn (two elbows) and a non-finned pipe that goes under and back the other way so both inlet and outlet are at the same end of the unit. This may permit installing it in front of the pocket door pocket.
Bob999 01-21-2011 05:05 PM
Here is one manufacturer of units that would satisfy your requirements:
http://www.runtalnorthamerica.com/re...ors/index.html
