Old 08-22-2010, 10:27 PM   #1
Anti siphon valve leaking
On an outdoor frost proof faucet, the siphon valve leaks whenever the water is turned on. I removed the threaded cover piece and found a plastic insert with a center piece that moves. do I need to replace the entire faucet? does this piece come off and can it be replaced? or do I need to do something unknown to stop the leak.
Thanks!
net4profit is offline   Reply With Quote
Old 08-23-2010, 12:32 AM   #2
most will unscrew, if you can find the exact same hose bibb or repair parts you can replace the piece but if not you'll have to replace the whole valve. Most of the time they are proprietary parts that don't fit brand to brand
the_man is offline   Reply With Quote
Old 08-23-2010, 06:10 AM   #3
Do I assume the hose bib is defective? is there anyway to check, or is it as simple as leaking = defective?
Old 08-23-2010, 09:08 AM   #4
I wouldn't call it defective, just worn out. That anti-siphon valve has a little piece of rubber inside it that is the problem, the rest of the bibb is fine. The problem is always finding parts for them, a lot of the time it's easier to change the whole unit out
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
Leaking shut off valve, am I that inept??? ChrisDIY Plumbing 12 07-28-2012 08:52 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 06:03 PM
