Old 06-17-2009, 12:47 PM   #1
anti-freeze spigot
I have a anti-freeze faucet that when you turn it on with nothing attached to it, it flows fine, but when I hook up a garden hose, the water comes out the top of the spigot, or cap. How do I fix this? Jay
byrd316 is offline   Reply With Quote
Old 06-17-2009, 02:42 PM   #2
DIY'r
ScottR's Avatar
anti-freeze spigot
Looks like you need to replace the washer at the top of the valve stem (this pic is of an anti-freeze faucet):
I know this is not the same type of valve as yours, but the idea is the same:
Remove the handle (using the screw in the middle), then use a wrench to remove the packing nut. The packing washer is what you'd need to replace. Most any hardware store/home center should have the kind you need.
It works fine with no hose connected b/c there is no back pressure -- water will take the path of least resistance, so it's going right out the spigot. A hose increases resistance, and will force some water to seek another path, in this case out around the packing washer.
Unless I've misunderstood where the water is coming out..
ScottR is offline   Reply With Quote
Old 06-17-2009, 03:34 PM   #3
the Musigician
DangerMouse's Avatar
anti-freeze spigot
it MAY be as simple as tightening the packing nut too, try that first.
if it still leaks, then ScottR is correct on how to continue from there.
but then again, he is a prize-winner from the faucet knob thread too..... lol
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 06-17-2009, 04:39 PM   #4
DIY'r
ScottR's Avatar
anti-freeze spigot
Hmmm.. you might just be the winner of this thread..
Old 06-17-2009, 04:41 PM   #5
the Musigician
anti-freeze spigot
huh! you might be right! lol
but we may never know.... sometimes they never return.......
DM
Old 06-18-2009, 01:00 AM   #6
anti-freeze spigot
If it looks similar to this the cap on top is a pressure release and may just need to be tightened by turning the cap.
hayewe farm is offline   Reply With Quote
Old 06-18-2009, 02:01 AM   #7
master plumber
cincy plumber's Avatar
anti-freeze spigot
The vacuum breaker needs to be repaired,if it is like the one in the pic.
If not then the packing nut deal.
cincy plumber is offline   Reply With Quote
Old 04-07-2012, 04:17 PM   #8
anti-freeze spigot
I have an anti freeze spigot and when I turn it on with a hose attached water flows out of the handle. IF there is a packing nut it is inside and I cannot get to it. What is the answer on how to fix this leak that comes out just before the handle?
wwilber is offline   Reply With Quote
Old 04-07-2012, 04:25 PM   #9
the Musigician
anti-freeze spigot
You'll likely get better responses if you post a NEW thread in the plumbing section with your questions.
DM
Anti Freeze OK to use in sprayer? brokenknee Painting 10 03-30-2009 07:36 PM
Hot Water Heater Spigot Leak ellisje007 Plumbing 9 01-24-2009 08:52 AM
Outdoor Spigot Leak ryvanslo Plumbing 7 12-17-2008 05:37 PM
Roman Tub Spigot Problems - Phoenix Corp? bkw Plumbing 1 10-17-2008 04:21 PM
Installing a Hot / Cold Water Spigot dc2295 Plumbing 1 02-25-2008 06:10 PM
