Old 03-30-2012, 08:58 AM   #1
Another Water Heater Smell Question
I just replaced a 20 year old electric water heater with a new American 40 gallon electric. I now have the smell problem on the hot water.
I have called American and talked to local plumbing supply companies. I get conflicting info so I'm here for help.
According to American, the new unit is supplied with a 3/4" aluminum anode rod. I've read that magnesium and aluminum cause the smell problem and zinc prevents it. Problem is, I get conflicting info about this at the local plumbing supply companies.
I'm on well water with a salt based softener tank and a separate iron treatment tank.
Will the zinc rod eliminate the smell? How long do they normally last before replacement?
Earnie is offline   Reply With Quote
Old 03-30-2012, 10:39 AM   #2
Doing it myself
Alan's Avatar
To answer both of your questions with a single answer : It depends on what is in your water. Well water makeup varies so greatly, there's no telling what is causing the 'reaction' that is making the bad smell.
The only thing you can do is try it.
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
ben's plumbing (03-30-2012), jaydevries (03-30-2012)
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
