Another Vent Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2013, 09:11 AM   #16
Originally Posted by hammerlane View Post
Fitting "A" looks like a 3x3x2 Wye and it is being used as the toilet vent. What is the problem you see with that??
Shouldn't the WYE fitting A be turned around?
mikem201 is offline   Reply With Quote
Old 01-23-2013, 09:17 AM   #17
Rewards Points: 2,516
What do you mean by turned around? Along which axis?
hammerlane is offline   Reply With Quote
Old 01-23-2013, 09:18 AM   #18
i mean just turned around horizontally like it is now but with the ends switched around.
Old 01-23-2013, 09:21 AM   #19
No...the way it is now helps promote the air flow from the vent as the water drains past it. Imagine the air as the green line with the arrows.
Old 01-23-2013, 09:23 AM   #20
oh im sorry. The way I figure it was you want the gaseous air behind the waste to escape that is the reason for the vent. Was I wrong?
Old 01-23-2013, 09:24 AM   #21
Plumber
TheEplumber's Avatar
Rewards Points: 904
San T vs. Wye & 1/8
Help me understand your first image- it says code violation to me.
The center image is missing the left side of the pipes- that is the part that makes the combo wrong. As shown, the combo is fine.
Old 01-23-2013, 09:29 AM   #22
first image...center image...Its says code violation....combo wrong...combo is fine. Cant make sense of what you are asking/saying.
Sorry
Old 01-23-2013, 09:31 AM   #23
posted images for reference
Another vent question-when-20to-20use-20san-20t-20wye-201-208.jpg   Another vent question-proper-20placemet-20wye-20san-20t.jpg
Old 01-23-2013, 09:34 AM   #24
The purpose is to vent the sewer gases using the vent so what do you mean about allowing air from the vent back into the pipe?
Old 01-23-2013, 09:35 AM   #25
You need air behind water.
Old 01-23-2013, 09:36 AM   #26
So how do you know what position to place the vent? You have to vent the gases and bring air in, correct?
Old 01-23-2013, 09:39 AM   #27
When water is not flowing through a sewer pipe, the pipe is able to maintain neutral air pressure when compared to its surrounding atmosphere. When waste water moves through the pipe, however, it can act like a piston. The air downstream can become compressed. This creates positive pressure in the pipe. The air upstream can pull a vacuum, and this pulls back on the waste.
The positive pressure in the pipe needs to be released. Otherwise, it will push back against the waste stream. At the same time, there must be air flow behind the waste stream. If there is not, negative pressure will occur and this will result in suction. The volume of the waste that was discharged will determine how much pushing or suctioning takes place.
Old 01-23-2013, 09:42 AM   #28
Plumber
Rewards Points: 904
Where did you get this images?
C- you can't lay a sant horizontal on a drain.
B- Both fittings are correct- unless you are showing trap arms- it doesn't say.
C & A are the same
Old 01-23-2013, 09:42 AM   #29
But im asking you need to vent and bring air in so in what way do you place the vent pipe?
Old 01-23-2013, 09:44 AM   #30
Plumber
Rewards Points: 904
You really need to spend some time studying plumbing theory
fresh air vent question gregdk HVAC 2 09-05-2012 09:22 AM
Vent Question bigmark77 Plumbing 3 10-14-2011 09:36 AM
Water Heater Vent Question pd417 Plumbing 1 05-15-2010 12:34 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Return air vent question sidewayzisbest HVAC 5 05-10-2009 03:39 PM
