01-22-2013, 12:04 AM
#1
Another vent question
if a fixture is too far from the stack I know that it needs its own vent. For example if I have a 2 inch drain from a shower and since I need to revent it can I use a WYE fitting and run the vent from the top of the WYE then up and over to the stack?
01-22-2013, 08:22 AM
#2
Master Plumber
post your location. depending on your code, different locations different code
Experience is Knowing what to do next, Skill is knowing how to do it
01-22-2013, 09:16 AM
#3
code has nothing to do with what im asking.
01-22-2013, 10:03 AM
#4
Doing it myself
Uhhhhhh
Pretty sure it does.
If it doesn't, then why even bother venting it?
Journeyman Plumber
01-22-2013, 10:39 AM
#5
we used to use a san tee on its back for venting like that. inspectors approved of it. it had to be vertical or at most or least on a 45 degree angle.
01-22-2013, 11:01 AM
#6
call me E
How did you determine your trap is too far away? Did you just decide on a random length? Of course code has something to do with it
01-22-2013, 12:38 PM
#7
like this?
01-22-2013, 01:49 PM
#8
yes like that. That WYE pointing up should be used to vent that fixture, right? I have been told many time that san tee's should not placed on their sides.
01-22-2013, 09:48 PM
#9
Doing it myself
That depends on what it's being used for. The rules about this fitting and what it can be used for can be found in a CODE book.
Journeyman Plumber
01-22-2013, 10:47 PM
#10
Master Plumber
WOW I've been doing it all wrong for the last 35 years i knew i shouldn't have bothered worrying about all that code stuff been complicating my life worrying about a stupid code...
01-23-2013, 06:35 AM
#11
San T vs. Wye & 1/8
01-23-2013, 09:25 AM
#12
The picture you sent me previously with the WYE used for draining and venting at the top is the WYE positioned right though? Looks like its venting the toilet?
01-23-2013, 09:53 AM
#13
Doing it myself
Right according to...... ?
Journeyman Plumber
01-23-2013, 09:58 AM
#14
Fitting "A" looks like a 3x3x2 Wye and it is being used as the toilet vent. What is the problem you see with that??
01-23-2013, 09:59 AM
#15
Roofmaster
Hey Allen, How come the Uniform Plumbing Code is anything but Uniform?
Why dont they call it the Variable Plumbing Code? or the It depends on the whim of your Inspector, code?
Does poop have a mind of its own, and it acts differently in different places?
Yes this is a rhetorical question.
" A lot of men build things, and a lot of things fall down "
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
