Another Toilet Hiss Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-10-2012, 01:32 AM   #1
another toilet hiss question
this goes on all day. i live in a condo. at night it is quiet unless i turn on any faucet. i have shut off the valve just to stop the noise sometimes. i know nothing about plumbing pipes valves. i am thinking there is something wrong with the water pressure in our building but a plumber who came by wants to sell me an entire new toilet. this toilet is nine years old. does shutting the valve do any kind of damage until i need to use the toilet? the hiss can go on every six minutes depending on the time of day.
nataled is offline   Reply With Quote
Old 09-10-2012, 04:30 AM   #2
DIY staff
Rewards Points: 7,174
You have a leaking fapper ---that's my guess--have you lifted off the top of that tank and looked inside after you have had the water turned off?
Look---see if the water level in the tank goes down over night---if so---you need a flapper or a flapper and seat---
Next possibility---if the tank is over filling---water will run into the round over flow tube----and make the toilet run---to fix that---adjust the float on the flush valve----
Last possibility----The flush valve is defective---and goes off with the pressure variations in the building---change the flush valve.
The plumber may have detected a flaw in the toilet and suggested changing it for that reason---or the toilet is an economy model ---or he has a boat payment due and needs the sale.
Old 09-10-2012, 07:13 AM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 996
The plumber may have detected a flaw in the toilet and suggested changing it for that reason---or the toilet is an economy model ---or he has a boat payment due and needs the sale.[/QUOTE]
LOL most likely
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 09-10-2012, 07:21 AM   #4
Rewards Points: 13,750
Take the cover off of the tank, add a few drops of red foor coloring. If the red ends up in the bowl the flappers leaking, or the flapper seat is dirty.
Any DIY can rebuild a whole toilet in about an hour with about $20.00 worth of parts, and a few simple hand tools. If you go on The Fluid Master web site it will have a full break down, parts needed, trouble shooting, and instrutions on how to do it.
toilet wax gasket Question dogbrother Plumbing 0 03-10-2012 03:39 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Bubbling toilet question. mikeschildt Plumbing 1 08-04-2011 08:33 PM
Fernco wax free toilet seal question? masterblaster4 Plumbing 2 07-21-2011 10:56 AM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 10:12 AM
