#1 |
Another toilet flange question
Hey all,
Has anyone used or heard anything positive/negative about the toilet flanges that fit INSIDE of a stack? This would save me some work in my basement but heard cases of it being prone to plugging? Thanks to all you fine people! |
#2 |
Super Moderator
They are not prone to plugging----
However----the 3" inside flanges have a small opening and often cause installation problems---if it is mounted on top of the finished floor--sometimes the toilets drain horn will hit the inside of the flange,causing the toilet to bottom out and rock--- If you do use one---make sure the flange is flush to the finished floor. I've had trouble with these several times and will not use them.
New members: Adding your location to your profile helps in many ways.--M-- |
| The Following 2 Users Say Thank You to oh'mike For This Useful Post: | jagans (01-25-2013), paintdrying (01-25-2013) |
| Display Modes | |
| 3" ABS toilet flange 3 1/2" too high in basement floor | fusion2k | Plumbing | 3 | 08-26-2012 01:41 PM |
| Question about toilet flange | darius | Plumbing | 13 | 05-16-2012 12:16 AM |
| Changing out carpet for tile - toilet flange? | M3 Pete | Plumbing | 4 | 02-16-2012 11:20 PM |
| Toilet flange questions | AngeloUCF | Plumbing | 16 | 03-09-2011 09:39 PM |
| Toilet flange question. | speedster1 | Plumbing | 4 | 04-07-2010 11:30 AM |
