Another Laundry Sink Addition Question... - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-06-2013, 09:18 AM   #1
Rewards Points: 33
First, thanks to those of you who helped with my question about adding a laundry sink to my washer drain pipe stand. I have decided to put the sink on a different drain on the other side of the room.
Currently (see attached picture), there is a hose draining AC condensation to that drain and then some other small pvc line running to it from the furnace. Could that small pvc line be to drain off any furnace moisture? It doesn't seem like there is ever anything flowing through it.
Could I...
1) Delete the existing trap (again see picture)
2) Put the sink with p-trap into that drain
3) "T" in the small pvc drain from the furnace under the sink p-trap
Thanks again!
Koellert is offline   Reply With Quote
Old 03-06-2013, 10:06 AM   #2
Roofmaster
Rewards Points: 2,172
You have a condensing furnace which produces water by burning natural gas. If the furnace is running, and not producing condensate, something is wrong. Your trap and condensate lines are probably plugged up with crap. They should be cleaned once a year. Condensing furnaces produce a lot of condensation. Have you had water on the basement floor under the furnace?
I drain my AC and Furnace condensate into a small plastic catch pan that drains right through a hole that goes down through my basement slab into the clean stone below. From there it percolates down through the ground. This works great.
The trap you have is not vented, and could siphon out. It will dry out if the furnace or AC is not running, and you will have sewer gas in your house. If it dries out you could draw sewer gas into your furnace, because I dont see a trap on your AC drain, which is a hose. Bad setup.
I like the "Open Concept" commode, reminds me of my stint in the Military.
Old 03-06-2013, 10:21 AM   #3
Rewards Points: 33
What if...
I put a "Y" on the existing trap... one branch is connected to the new sink drain, the other remains open for the two condensation lines to drip into (not hard connected). Would sink flow back out of the open part of the "Y"?
I want to avoid putting on a condensate pump, but is that my best option?
Also, is it possible that there is already a trap under the cement and that the above-floor trap was put on for no reason? How could I find out... cheaply?
Thanks for the help!
Old 03-06-2013, 07:38 PM   #4
Rewards Points: 33
Anyone? Would the condensate pump be my best "fix"?
Also, there has to be a trap under the cement... doesn't there?
Home was built in '79. Before the trap in the picture was put on (2-3 years ago) it was just an open pipe. We've never smelled sewer gas.
Thanks again all!
Adding Laundry Sink notlawd1 Plumbing 2 01-02-2013 11:15 PM
Insulating a kitchen sink in an addition mariann carcich Kitchen & Bath Remodeling 1 04-06-2012 08:35 PM
Basic Question on plumbing (planning to unclog bathroom sink drain) babyfishmouth Plumbing 1 07-31-2011 01:14 AM
bathroom sink stopper question - Pictures in thread amodoko Plumbing 5 05-31-2011 06:24 PM
Laundry Room Dimension Question jonathan03 Appliances 1 01-17-2009 11:08 AM
