Old 01-31-2013, 09:25 PM   #1
another DWV review... please!
I'm remodeling a bath/laundry area in an old existing detatched building.
All lines will be ABS at 1/4" per foot. The back-to-back LAV's will have a double wye connection. Cleanouts are not shown but will be added.
I hope the pic isn't too hard to see.
Please let me know if there is a better way.
I've got a few specific questions...
1. I know the sink and washer should have their own vents, but can the main stack vent the utility sink and washer since the run is only 5'? I'd rather not hack the existing double 2x4 top plate out for a vent if the stack can do the job. Maybe I could just add an AAV to the sink if necessary?
2.Does the wc need a combo where it attaches the stack, or should I use a sanitary tee since it is also used to drain the (vented) LAV?
Thanks for any feedback!
Queso Bandit is offline   Reply With Quote
Old 02-02-2013, 08:50 PM   #2
Master Plumber
Javiles's Avatar
area location would help, relation plumbing code. under some you may be ok others not. sanitary tee on the toilet drop.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 02-03-2013, 12:09 PM   #3
Thanks for the reply
I'm in California. Is the code issue the laundry sink wet vent?
I believe wet vents are allowed for "bath groups only" but I don't see how this would function any different.
Old 02-03-2013, 02:35 PM   #4
call me E
TheEplumber's Avatar
I think you're UPC- TO answer your questions:
1.You can re-vent back to the stack or stack separate trap arms for each fixture as long as they're less then 5ft
Can not use AAV if a vent thru roof is possible
2. Tee is fine but your lav line is now considered the vent for the wc. So it must be 2" underslab as well as through the roof.
Use a "fixture cross" or stack tees for back to back fixtures- not crosses
Old 02-03-2013, 09:51 PM   #5
Hmmm...didn't think of two separate drain lines for the washer and sink.
Guess that's a way to meet code but I still don't see what's wrong with wet venting a washer that is rarely used.
Solaris Lawn Mower review dive_instructor Landscaping & Lawn Care 0 06-03-2011 10:29 AM
Review: Makita LS1016L Compound Sliding Mitre Saw and Makita 2704 Table Saw w/ Stand wnabcptrNH Tools 6 02-21-2010 07:52 PM
Tool Review: Skil 3.6V Li-ion iX03 Screwdriver cduguay Tools 0 01-19-2010 12:52 PM
review my kitchen circuit plans DanBress Electrical 9 03-08-2008 07:07 PM
