Another Drainiage Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2009, 12:03 AM   #1
another drainiage problem
Another problem as you can see from the pic the y I have on my washer tie in is causing me to lose slope of my drainage pipe
i got slope almost to the y and then a little farther down the line
my problem is The washer drain sits on top of one of the main beams
what do I do here?
knotch it? wont it weaken it?
also how to I make the drain have a slope with this type of connection it tries to make it strait is there some kind of flexible pipe i could put on the end to connect it to the y?
Im getting aggravated at this really i need some help please
rebelbull is offline   Reply With Quote
Old 03-31-2009, 08:47 AM   #2
Rewards Points: 1,538
Do not notch the beams or joists.
If you had to reposition the existing drain pipes to install a washing machine drain and lose the necessary slope, then you made a bad choice of location for the washing machine drain.
Also do not splice on to a washing machine drain hose unless the instruction manual specifically says you may. The built in pump is only strong enough to pump water the length of the supplied hose to a loosely fit drain connection or laundry tub. You can build a platform to put the machine on so the hose will reach a drain connection near the ceiling.
In addition there must be a trap in the washing machine tie in, I think 24 inches below where the machine hose is plugged in and then you connect to the main drain.
Problem with fan coil unit/hydronic system. flood1911 HVAC 2 09-05-2008 04:57 PM
2 switches , one light problem pepperthecat Electrical 2 07-08-2008 03:57 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
