Another AAV Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-18-2011, 09:06 AM   #1
Rewards Points: 27
Another AAV question
I've got a sink, shower, and toilet that I need to drain. The only ready place to put a vent pipe is the stack. The stack will be about 10 feet from any of the fixtures. So, I'm thinking I should also place an AAV along the drain.
Can I service all 3 fixtures with a single AAV? I've heard up to six is okay. If so, can I place the AAV anywhere along the drain (for example, at the point just after the last fixture drain)?
Thanks,
Eric
mn1247 is offline   Reply With Quote
Old 06-19-2011, 06:32 AM   #2
Rewards Points: 27
Just to follow-up a bit, my drain system begins with a sink drain, then has a shower drain, and then a toilet drain. I'm wanting to put an AAV just after the toilet drain. There will be a roof-vent pipe after this (about 10 feet away).
Is this okay? Any advice?
Thank,
Eric
Old 06-19-2011, 06:59 AM   #3
It would be easier for people to comment if you could give us pictures and/or diagrams of what it is you're trying to accomplish.
My first thought, though, is that you don't need an AAV is there's a vent stack 10 feet away. And the way you're describing the location of the single vent for all three fixtures isn't right. (You can get all three fixtures vented with a single vent, just not the way you've described).
Ishmael is offline   Reply With Quote
Old 06-20-2011, 01:50 PM   #4
Rewards Points: 27
Thanks for the thoughts. I'll try to post a diagram. But basically, the fixtures that need to be drained are currently connected to a drain pipe in this order:
Sink -> Shower -> Toilet.
There is no place in that area where I can readily run a vertical pipe up to the roof. Hence, I'm wanting to use an AAV.
The only place I can readily place a vertical pipe up to through the roof is at the point where the septic connects, about 10 feet downstream and away from the sink/shower/toilet.
Suggestions?
Eric
Old 06-21-2011, 11:02 AM   #5
Rewards Points: 27
Okay, here's a diagram of what I'm trying to do. Because of some huge beams at the edge of the barn, I'm not sure I can install any vertical vents in the area shown. Can I use AAV?
Thanks,
Eric
Old 06-21-2011, 11:04 AM   #6
Rewards Points: 27
the diagram...
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
