Anode Rod - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2011, 10:36 AM   #1
Rewards Points: 256
Anode Rod
I am getting ready to replace abaout 3 anode rods in water heaters for rental units.
Because of clearance issues, I will need to get flexible ones. Since I will be ordering several I need to get this right.
There seem to be several material choices with some big price differences.
Which metal is best? Which is best value? I live in an area with very hard water: Does that make a difference?
michaelcherr is offline   Reply With Quote
Old 01-04-2011, 10:56 AM   #2
Check with the manufacture of the water heater. Some are different materials
semore 102 is offline   Reply With Quote
Old 01-04-2011, 05:13 PM   #3
Rewards Points: 1,538
Magnesium protects the tank better than aluminum although sometimes magnesium results in bad odors to some kinds of hard water. Aluminum is better than zinc.
Choose the best anode material for the water and situation even if it costs more.
Bradford White Water Heater Anode Replacement pgs Plumbing 3 05-04-2010 05:58 PM
Sign of deteriorating water heater anode? Frank O Plumbing 18 02-28-2010 12:52 PM
Sacrificial anode replacement. rjniles Plumbing 3 02-27-2010 05:05 PM
Bradford White sacrificial anode replacement problem vinnie1 Plumbing 3 07-27-2009 08:01 PM
Teflon tape or pipe dope an anode rod? Nestor_Kelebay Plumbing 4 02-08-2009 10:42 PM
