Anode Rod - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2012, 01:49 PM   #1
Anode Rod
Any tips on removing anod rod? I have added a 7' pole on my breaker bar, still will not budge.
Doug60m is offline   Reply With Quote
Old 01-15-2012, 02:01 PM   #2
Rewards Points: 14,014
Air impact tool.
What makes you think it needs to be changed?
Old 01-15-2012, 02:01 PM   #3
If you have access to an electric impact, or rent one maybe. Richard on This Old House makes it look easy.
Hardway is offline   Reply With Quote
Old 01-15-2012, 10:28 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
You’ll need to give it a little heat, Be very careful, how old is the tank? Gas or electric, may not be worth changing if the tank is over 5 years old. Anodes if you’re trying to extend the life of the tank should get changed when the tank is new every 4 years. And tanks need to be flushed once a year.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-16-2012, 07:27 AM   #5
Gas heater 2 years old, very bad smelling hot water. Just drained the tank 3 or 4 months ago.
Old 01-16-2012, 08:31 AM   #6
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Doug60m View Post
...drained the tank 3 or 4 months ago.
and what came out?
what sort of water do you have?
and is it especially hard or mineral laden?
Old 01-16-2012, 09:02 AM   #7
Rewards Points: 352
They make a anode rod that screws into the outlet just like changing a nipple. Just leave the old one alone
plumberinlaw is offline   Reply With Quote
Old 01-16-2012, 09:18 AM   #8
on this old house Richard says every two years.
Old 01-16-2012, 09:22 AM   #9
Doug read this:
http://www.doityourself.com/forum/wa...hot-water.html
http://www.smellywater.com/
Old 01-16-2012, 09:26 PM   #10
Rewards Points: 27
You are just going to cause a leak in the sweat fittings atop the unit.
Get a 1-1/16" impact socket and an AC-powered impact tool. It will take 3 seconds to break it free.
Wrooster
wrooster is offline   Reply With Quote
Old 01-27-2012, 02:26 PM   #11
Rewards Points: 1,216
Just replaced my anode rod which was eaten up.
Thanks to you guys that recommended the impact wrench, couldn't have done it without that.
COLDIRON is offline   Reply With Quote
Question about removing Bradford & White anode rod Suzeroo Plumbing 0 04-01-2011 09:19 PM
Changing anode rod joeg679 Plumbing 23 02-15-2011 09:21 PM
Sign of deteriorating water heater anode? Frank O Plumbing 18 02-28-2010 12:52 PM
Sacrificial anode replacement. rjniles Plumbing 3 02-27-2010 05:05 PM
Teflon tape or pipe dope an anode rod? Nestor_Kelebay Plumbing 4 02-08-2009 10:42 PM
