| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Before Installing Sprinkler Heads
by Expert Village
Hi this is Fernando we are here with Expert Village and now we are going over before you actually start installing a sprinkler heads. We have laid down our pvc piping, we have connected our pvc pipes, we have actually done our joining corners and we seal... Read More »
Choosing The Right Powered Paraglider
by Expert Village
Welcome to Expert Village. My name is Hugh Murphy with Surf the Sky Paragliding. In this clip, we're going to talk about the anatomy of a paraglider and how to choose the proper paraglider for your configuration. The first part of the paraglider is... Read More »
Photography Studio Equipment: Ripstop Nylon
by Expert Village
In this clip I want to talk a little bit about the fabric that's used in this. This is rip-stop nylon, which is available at almost any fabric store. It's not very expensive, it has lines going through it so if it gets a tear it won't tear very far... Read More »
How to Remove a Spark Plug
by Expert Village
Hi, this is John on behalf of Expertvillage.com. In this video clip, I will be showing you how to remove a spark plug. The tools that I will be using to remove the spark plug are a 3/8 inch ratchet, 3/8 ratchet extension and a 5/8 inch socket and I... Read More »
How a Sprinkler Head Works
by Expert Village
Hi I'm Fernando with Expert Village going over how a sprinkler head actually works and as you can see this sprinkler is connected to the pvc piping. When the pressure comes from the valve which is the water rushes in and fills up the piping it then goes... Read More »
