Angle Valves To Control Faucet Volume - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-06-2012, 06:24 PM   #1
Angle Valves to control faucet volume
Quick question about the proper use of angle valves, AKA shut off valves under sinks. I am trying to reduce my water bill and think that I can save a bunch of gallons used by decreasing the volume of water flowing through my common used faucets. Right now the pressure is so great that when I turn on the kitchen and bathroom faucets, the amount of water coming out is unnecessary and habit is preventing me from just opening the faucet less. So is it safe or recommended to have my shut off valves half open to reduce volume? It seems to work well for reducing volume, but I am not sure how safe this is for the valves. Any thoughts or experiences will be appreciated.
James Rowell is offline   Reply With Quote
Old 12-06-2012, 06:44 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Angle stops are considered full open valves, not for volume control though its done often.
Old 12-06-2012, 06:47 PM   #3
Rewards Points: 13,300
Why not just lower the pressure if it's to high?
Old 12-06-2012, 07:31 PM   #4
Well I am currently renting this house and I am not sure of an easy way to reduce the pressure. I like the pressure for the toilets and showers, but I don't need to rip my skin off when washing my hands. That is why i thought the shut off valves would be a good route. What are the risks to using the shut off valves to reduce volume?
Old 12-07-2012, 06:49 AM   #5
DIY staff
Rewards Points: 7,174
No risks ----might make noise---biggest risk is the old valve leaking the moment you turn it---
Consider changing the aireators to a flow restricted one---
Old 12-07-2012, 08:43 AM   #6
Rewards Points: 582
while everybody has good suggestions....the proper fix is installing a pressure reducing valve....not just to save water,volume, or money.....its protecting the property for major damage due to line burst because pressure is to high...btw whats too high....how much is it did anyone put a guage on it ..ben sr.
Old 12-07-2012, 01:00 PM   #7
Special User
Rewards Points: 1,230
The old multi-turn stops should not be used to choke the flow down. They aren't designed for it and the rubber washer inside can rattle, moan, and make noise as it shreds itself. Soon the washer is toast, and it won't shut the water off when you need it to.
The newer quarter-turn stops, assuming they are like a ball valve internally, could probably withstand being choked down. Gonna be hard to find that sweet spot between "too little" and "too much" flow though.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-07-2012, 02:38 PM   #8
I actually just installed quarter turn valves because when I went to shut off the valves they leaked incredibly. I am guessing that they were 20 years old. So after spending money on replacing the valves, I don't want to do anything that would cause the new ones to leak. Maybe a water saving aerator is a good option. Will the quarter turn valves get damaged quickly if they are shut half the way?
Thanks for all the answers.
Old 12-07-2012, 04:52 PM   #9
Rewards Points: 582
PRESSURE REDUCING VALVE....ben sr
Faucet Leak below kitchen sink and from the Delta faucet: Replace or Repair? spyboy Plumbing 14 05-13-2014 08:03 PM
Frozen outside faucet leaks -> Hose left attached k6trouble Plumbing 13 07-01-2013 12:29 PM
Pressure Change on Outdoor Faucet mrhudock Plumbing 0 04-11-2011 10:34 PM
Variable speed pumps and cycle control valves NHMaster Plumbing 0 02-25-2010 06:55 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
