Angle Valve On 1/2" Copper Tube For Bathroom Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2011, 01:25 AM   #1
Angle valve on 1/2" copper tube for bathroom sink
I have an angle valve to put on 1/2" copper pipe to supply the bathroom sink with water. I'm not sure how this valve attaches or even what it called? It's a valve with a plastic tube that has a rubber gasket on it then a sleeve slides over the assembly and tightens to the valve. Please help this misguided plumber!!!
Bigb142 is offline   Reply With Quote
Old 12-10-2011, 05:15 AM   #2
DIY staff
Rewards Points: 7,174
Is it possible to post a picture? Are you trying to replace it? Tell us more---Mike--
Old 12-10-2011, 07:33 AM   #3
Home stores have fairly good books for the DIY'er. You need to get a plumbing book and learn to identify the various connection methods. Otherwise, you could end up with a lot of water where you don't want it.
It sounds like you are describing a compression type fitting. There is a brass sleeve(ferrule) inside the fitting that compresses around the pipe as you tighten it. Getting it tight is important or you will have leaks. I usually use plumbers grease on the ferrule and threads which allows you to tighten things easier.
Old 12-10-2011, 08:04 AM   #4
DIY staff
Bill--I think he is describing a 'shark bite' style push on thing with the water line already attached--
If that's the item----I don't like them--at all---pure junk and damn near impossible to remove if you have trouble.
Old 12-10-2011, 09:24 AM   #5
Rewards Points: 13,300
Without a picture anyone can only guess on this one.
Tags
bathroom , plumbing , sink , supply , valves
1/2" OD copper to 1/2" nominal with T connector? bobpiker Plumbing 9 02-26-2009 12:06 PM
Copper pipe + galvanized valve - Bad??? davefr Plumbing 2 04-25-2008 11:41 AM
Old preasure valve, new copper pipe. fast380 Plumbing 5 01-12-2008 11:36 PM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 01:28 AM
1/2" Self Tapping Valve wbjdmd Plumbing 2 09-17-2006 11:01 PM
