Angle Stop Seized On Iron Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-17-2012, 04:56 PM   #1
Angle stop seized on iron pipe
I am trying to replace a angle stop but I can't get it to break free from the iron pipe. I sprayed it with PB Blaster and let sit for 30 min or so and it still won't budge. Any tips on breaking it free?
Chriscomp is offline   Reply With Quote
Old 07-17-2012, 05:20 PM   #2
Rewards Points: 93
Larger pipe wrench
George6488 is offline   Reply With Quote
Old 07-17-2012, 05:39 PM   #3
Rewards Points: 582
alittle heat should do it...
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (07-18-2012)
Old 07-17-2012, 06:48 PM   #4
DIY staff
Rewards Points: 7,174
You are using two wrenches,right?--Breaking that pipe inside the wall ruins a good day---
ben's plumbing (07-17-2012)
Old 07-17-2012, 07:20 PM   #5
Rewards Points: 14,306
Only once I've had to use a Dremal tool with a cut off wheel to split the valve in 1/2 on both sides, where the threads sit to get it to come loose.
You really should concider getting rid of all that old steel pipe. It's going to leak at some point and reduce the flow in the lines.
Old 07-17-2012, 09:43 PM   #6
Got it! I guess I just needed to let the PB Blaster sink in a little bit longer.
split cast iron pipe lstroble97 Plumbing 13 12-31-2011 01:17 PM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 01:42 AM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Cutting Iron Drain Pipe jonathan03 Plumbing 12 01-31-2009 09:33 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 08:20 PM
