Which Anchor To Use For Toilet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2011, 03:44 AM   #1
which anchor to use for toilet flange
I am installing a new toilet for a basement bathroom. Rough-in toilet closet flange is PVC which wasn't level. I installed tile and am using a PVC spacer ring, one edge is slightly higher on one side above tile and about 1/4 inch higher on the other side. Hopefully this is acceptable and wax ring compresses without any problems to form a good seal. I need to fasten spacer ring to closet flange. (I'm assuming closet flange is glued to plumbing below the floor in the concrete, it isn't flush with top of concrete.) So I'll use silicone to seal spacer ring to closet flange, and concrete screws through top spacer ring into the concrete below. Are Tapcon concrete screws the fastener of choice here? Will the standard Tapcon screw be corrision resistant enough? Also how many screws do I use in the 8 holes on the flange, all 8? Finally, do i use 3/16" or 1/4" screws? Thank you.
8roty is offline   Reply With Quote
Old 12-09-2011, 05:28 AM   #2
DIY staff
Rewards Points: 7,174
The existing flange---How far is that Below the finish floor?
If the flange is cocked 1/4" you might be best to use a thicker ring in this case--than adding the plastic extender ring.
I have never had a problem with Tapcons--use them---To early in the morning for numbers---use the one with a head that fits the hole in the flange----if the flange has 8 holes--fill all 8---
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 08:39 PM
Closet flange too high dank Plumbing 8 04-14-2010 01:23 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 08:22 AM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
