Analyzing My Copper Pipe Sweating After 12 Years - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-27-2012, 01:43 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,132
We bought our 'fixer upper' house in 2000....one of the first things we did was gut the kitchen and remodel it. Which included me redoing all the plumbing in the crawl space. The 50 year old house had already be repiped with copper...but as with most of those jobs, the pipes were just pushed up through the floor instead of put in the walls.
At the time I thought I was a pretty good pipe sweater...hey....if they didn't leak...I must be pretty good.....
Yea....right.....
I've learned a lot since then.....like how important it is to debur the inside (cuts down the noise)....and getting them clean.
Well...as part of my 2-story addition, I moved the water heater from the front of the house to the rear...and recycled the 3/4" copper pipe....most of it was M so it was too good to not reuse....
Tonight was was cleaning up some of those pieces to reuse....I prefer to just un-sweat a connect and take it off...clean up the end and it's ready to sweat onto a new fitting.....
Well....it would seem that some of my "didn't leak" connections were borderline at best....
When you have a perfectly sweated joint....this is how it looks internally....
As you can see in the 1st 2 pics, I had voids where there was no solder....if they had been a bit larger...I think I would have had leaks. It basically proves that I did a poor job of cleaning...
Additionally, none of the insides of the pipes were debured....they all had rolled up edges from the pipe cutter. If you hear the water running in your house...it's most likely because the pipes were not debured.
I had one plumber tell me that deburing also reduces the chance of a pinhole leak later on. Something about the turbulance at the edge causes erosion at the joint.
So I humbly submit myself to the plumbing Gods for forgivness of my sloppy ways...
ddawg16 is online now   Reply With Quote
Old 12-27-2012, 08:51 AM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 990
Make an offering to the plumbing gods for you pasts piping sins or you'll be tossed in to DIY hell.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-27-2012, 05:01 PM   #3
Rewards Points: 1,216
I wouldn't have reused M I would have tossed it. I only use L or K if underground. Of course it's just an opinion.
M -thin-
L- thicker
K thickest.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 12-27-2012, 05:16 PM   #4
JOATMON
ddawg16's Avatar
M -thin-
L- thicker
K thickest.
My mistake....it's L....Blue stripe......
None of it is going in the ground....I have maybe 6" in the crawlspace and all the rest is in the walls and ceiling.....
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 03:46 PM
How To Bring Copper Pipe Through Concrete Block Starlight Plumbing 14 12-15-2012 08:48 AM
Compression Valve for leaky pipe (not copper)? DIYsoon2Bpro Plumbing 11 01-18-2012 07:40 PM
Why do they make copper plated steel pipe hangers? tractorfarmer Plumbing 0 01-15-2012 07:55 PM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 05:03 PM
