Amtrol Boilermate, Thermostat Well, Watertight? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2010, 11:22 AM   #1
Rewards Points: 150
Amtrol Boilermate, thermostat well, watertight?
Grrr. Let me start off by stating that I am not a plumber. I don't claim to be a plumber. I don't even play one on TV. I'm an electrician. I play with wires. I don't like pipes and I don't like working on anything that has the ability to flood the basement.
That said, a low-income friend of mine needed a water heater replaced, and stupid me agreed to it. "It's only four pipes and a thermostat wire. How hard can it be?!"
If somebody really wants to know, I'll explain how I wound up in my current situation, but I'd rather avoid the embarassment and just ask, simply, is the thermostat well isolated from the inside of the tank? ie, assuming I can't get the retainer bolt back in where it goes, if I devise another way to make sure the sensor bulb stays all the way up in there, but my new method isn't waterproof, will I wind up with water all over the floor?
emolatur is offline   Reply With Quote
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 11:07 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 10:21 AM
