American Standard Toilets - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-04-2012, 08:04 PM   #1
Rewards Points: 121
We bought two new American standard dual flush Toilets a little over a year ago and one is leaking alot and the other one is leaking very slow..I took the flush valve out of the one leaking alot and noticed the seal was not level, it was bubble up on the one side, looks like it was made of a silicone,
So i called up American standard and told them what i found and , and they already new that there was a problem with them , he said that was the first run, since then they have changed the seal..So they are sending me two new flush valves, nothing like the older toilets, with the flapper, these dual flush you have to change the whole unit.It's easy to change, you first turn the water off at the toilet and then you just turn the flush Valve and it lifts out..
We are on a well so when a toilet is leaking we know it, because the pressure pump will run.. 'anybody on city water may not even know these toilets are leaking if you have one you should check with American standard.
rick31797 is offline   Reply With Quote
The Following User Says Thank You to rick31797 For This Useful Post:
goosebarry (06-05-2012)
Old 06-05-2012, 08:16 AM   #2
Rewards Points: 242
Thanks for the tech tip. One of the reasons that I drop in occasionally is for this kind of advice.
Ed911 is offline   Reply With Quote
Gas furnace brands, which is better, Comfortmaker, American Standard, and Lennox? abefroman HVAC 10 04-22-2014 07:03 PM
American Standard Mr Smiley HVAC 4 02-24-2012 03:38 PM
Help with an American Standard Freedom 80 Furnace cschwer HVAC 21 02-09-2011 12:33 AM
Godman, Lennox, or American Standard homeowner12 HVAC 2 10-13-2009 06:54 AM
American Standard manual ct5 HVAC 1 01-29-2009 08:01 PM
