Am Standard Shower Mixing Valve Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2012, 05:20 AM   #1
WMS
Am Standard Shower mixing valve problem
I installed a new Am Standard shower mixing valve in a bathroom renovation. Water valves are on in basement but when I turned valve to test I got a quick spurt of water and then nothing. Any ideas? Do I need to adjust something on the new valve to get it to work?
WMS is offline   Reply With Quote
Old 02-13-2012, 06:56 AM   #2
DIY staff
Rewards Points: 7,174
Remove the shower head and test it again---sounds like the filter is clogged out---
ben's plumbing (02-13-2012)
Old 02-13-2012, 09:29 AM   #3
Rewards Points: 582
please tell me you took unit apart to install...don't take it personal..many have done this and damaged the cartiridge....ben
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (02-13-2012)
Old 02-13-2012, 09:47 AM   #4
DIY staff
Cooked guts,Ben?
Old 02-13-2012, 09:53 AM   #5
Rewards Points: 582
did one last week ho purchased from h d what amess he was not happy but Iam sure he learned something
Old 02-13-2012, 10:07 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is it a pressure balance valve? You got water pressure on both hot and cold?
Journeyman Plumber
American Standard intermittent inducer problem with presssure switch warning no such user HVAC 5 12-26-2011 06:20 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Moen Single Valve Shower Handle problem! F8James Plumbing 3 04-16-2011 05:32 AM
Can't Identify Shower and Tub rough in valve stamped SHWR 7196 and TUB P-P USA help4diy Plumbing 1 11-21-2010 10:06 AM
dual shower head mixing valve Clem Plumbing 0 10-20-2010 07:34 PM
