Am I Right...teflon Tape Not Needed On New Faucet Lines? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2011, 01:35 PM   #1
Rewards Points: 99
Am I right...teflon tape not needed on new faucet lines?
I am replacing plastic faucet and toilet supply lines today with braided hoses (plumber's suggestion after his last visit).
Am I correct in thinking teflone tape is not needed on the threads? The water boundary is at the compressed rubber gaskets, not at the thread to thread boundary as in a pipe to pipe fitting. This was the case in the instructions for my new dishwasher connection as well.
There was no teflon tape on the original install.
Thanks for any info.
Hossenfeffer is offline   Reply With Quote
Old 01-23-2011, 01:40 PM   #2
DIY staff
Rewards Points: 7,174
You are right --no tape--
Old 01-23-2011, 01:42 PM   #3
No tape! if you do put teflon tape on the fittings it is possible that it can get in where the rubber o-rings are and cause a leak. Not likely, definately worst case but still.....
kibblesret is offline   Reply With Quote
The Following User Says Thank You to kibblesret For This Useful Post:
oh'mike (01-23-2011)
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 05:02 AM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 06:56 PM
Is dry wall tape needed? Dr. Awsome Building & Construction 11 10-19-2009 07:10 PM
Opinion needed about changing kitchen faucet chris_p Plumbing 11 02-01-2009 10:39 PM
New Deep Tub ~ Needed Raised Deck .. Faucet for Deep Deck? Hisgirl Plumbing 1 01-17-2009 11:00 AM
