Almost Finishing Renovating The Kitchen, However! - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-03-2007, 07:59 PM   #1
Almost finishing renovating the kitchen, however!
Question, so it seems the new sink does not fully align with the pipe below it. So I figure I will get a plumber to get a flexible pipe and attach it on. My question for you guys is, so I firmly attach the countertop before this happens? Or should the plumbing be done first?
iOsiris is offline   Reply With Quote
Old 07-03-2007, 08:14 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Attach the countertop before the plumber arrives.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 07-03-2007, 08:35 PM   #3
Ok I see, thank you so much!
Old 07-04-2007, 06:50 AM   #4
Is the drain pipe for the sink plastic?
The pipe may have large nuts that allow you to adjust the final location of the connection to the sink. The trap can be loosened up and be moved left or right, the section that goes into the wall can be loosened up and be slide forward or back, the section that will connect to the sink drain can be moved up and down.
redline is offline   Reply With Quote
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
Finishing nail removal bklauer Carpentry 6 09-05-2006 07:13 AM
kitchen floor/underfloor heating LanterDan Flooring 2 07-04-2006 07:17 PM
Kitchen remodel frank551 Electrical 2 11-15-2005 07:13 PM
