All Toilets In House Will Not Drain. - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-21-2010, 07:55 AM   #1
all toilets in house will not drain.
My toilets will not drain, tried ridx 2 days ago, just had it pumped last year, gurgling in other bathrooms when we run water or try to flush!
amberrigsbee is offline   Reply With Quote
Old 07-21-2010, 08:01 AM   #2
Rewards Points: 352
sounds like your main is plugged, are all your toilets on the same floor? The gurguling you describe is air being forced thru your fixtures when it is displaced by water when you flush
plumberinlaw is offline   Reply With Quote
Old 07-21-2010, 08:13 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
You need to open a clean-out on your main line and snake the line with a heavy-duty plumber's snake to clear it.
If that doesn't do it (which it should), you may have to remove the toilets and snake from there too if things have backed up to them past the main line clean-out.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-21-2010, 09:01 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
By heavy duty, he means a 5/8 or 3/4" cable. Those little hand crankers you get at the home store will not do a bit of good. I'd call a plumber or drain cleaner.
Journeyman Plumber
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Running condensation drain into house drain log_doc_rob HVAC 2 09-07-2009 09:46 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
