All Steel Piping, What Should I Do? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2009, 08:38 PM   #1
Rewards Points: 184
All steel piping, what should I do?
This stuff is to the point where some of the joint are corroding and water leaks spring, should I replaced everything with all copper/pvc? Or is the a cheaper/easier solution?
abefroman is offline   Reply With Quote
Old 03-29-2009, 09:04 PM   #2
HVAC / Plumbing
Copper, Cpvc Or pex.......2 nd question .......no Your pipes are most likley galvanized & are corroded ... You will benefit by replacing
kenmac is offline   Reply With Quote
Old 03-29-2009, 09:28 PM   #3
Rewards Points: 184
Is there an easy way to replace them with minimal drywall/floor ripping up?
Old 03-29-2009, 10:24 PM   #4
HVAC / Plumbing
I don't know how they are installed.. Best advise I can give is do the least amount of damage as possible. Or leave the old pipes there & run the new pipe a different route that would do least damage
Old 03-30-2009, 02:55 AM   #5
G_P
sometimes you can snake PEX up the wall like electrical wiring but then it wont be supported inside the wall...... better off either redoing the drywall or calling a plumber.
G_P is offline   Reply With Quote
Floor bounce joist sistering joehomeowner Building & Construction 24 05-10-2009 02:50 PM
firring out concrete wall for electric and insulation trouble Building & Construction 9 02-04-2009 12:40 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Copper Or Iron Piping? beatboy77 Kitchen & Bath Remodeling 2 01-03-2009 01:36 PM
