All House Toilets Just Started Whistling?! - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-28-2012, 04:18 PM   #1
All house toilets just started whistling?!
Why do all house toilets on two floors whistle after flushing? This just started. We have hot and cold water running into our toilets since we live in cold weather state. Seems odd that they all had fill valve or flow constriction at same time?
hmritter is offline   Reply With Quote
Old 07-28-2012, 06:20 PM   #2
Rewards Points: 582
my guess its pressure related....do you have a pressure reducing valve ....
Old 07-29-2012, 06:55 PM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
I second that. My guess is that you do have a pressure reducing that has gone bad. Look around your main water shutoff valve for the prv
JDC is offline   Reply With Quote
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
