Airlock Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2013, 10:51 AM   #1
Airlock issue
This is my current plumbing under my kitchen sink:
As you can see I installed an OS&B ABS Air Admittance Valve above the sanitary tee, I installed it to get rid of the "glugging" effect when draining the sink or when the dish washer was on. I followed the supplied instructions for installation, and everything has been working fine until last night.
I'm now experiencing an airlock, which won't allow any flow out of the trap. The water backs up into the other sink drain. At first I thought I had an issue with blockage, so I ran my snake 20' without any obstructions. I then removed the AAV from the stack and the sinks drained normally. The valve is functional, it opens and closes and no glue got inside of it.
Why am I getting an airlock with the current setup I have?
OntarioCanada is offline   Reply With Quote
Old 02-01-2013, 11:06 AM   #2
joed's Avatar
Rewards Points: 12,862
I have to say the valve is not functional since removing it and allowing air in solves the problem.
Tags
aav vents , airlock , blockage
Westinghouse furnace issue joe8918 HVAC 9 12-04-2011 05:50 PM
how to reduce mositure issue on basement? diy001 Building & Construction 0 10-28-2011 12:44 PM
Perplexing AC issue AvalonGirl HVAC 22 08-17-2011 06:49 PM
Ceiling issue wooten General DIY Discussions 5 06-06-2011 07:20 PM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 01:08 PM
